Thermo Scientific - HERAEUS Cryofuge 6000i & 8500i
Low Speed Floor Model Centrifuge.The Cryofuge 6000i and 8500i are low speed centrifuges ideally suited for use in blood banks, biotechnology, and pharmaceutical industry where large volumes are centrifuged at high speeds and constant temperatures. Each offer optimized technology for all low speed centrifugation applications.
FORUMSView All (4)
0Replies18 days ago | Open door How to open lid in emergency Equipment: Thermo Scientific - HERAEUS Cryofuge 6000i & 8500i Reply |
2Replies13 years ago | yuss I need service manual for a Heraeus Cryofuge 8500.please send the PDF files.Email: il_yuss@aport2000.ruReply |
0Replies14 years ago | SERVICE MANUAL I need service manual for a Heraeus Cryofuge 8500.please send the PDF files. Email: servicetech7@gmail.comReply |
[list] [*] User friendly - Automatic lid locks enables the Cryofuge to be closed easily. Main control functions are conveniently arranged for easy access and the Cryofuge is equipped with 33 centrifuge programs for routine applications. Speed is controlled digitally with automatic RCF adjustments. Centrifuges can also be connected to a computer for data recording via a serial interface. [*] Powerful technology - The Cryofuge is equipped with a powerful, maintenance free induction drive for quiet and smooth operation. Its refrigeration system uses the environmentally friendly CFC free refrigerant R 404a. [*] Safety - When designing the Cryofuge, all international national safety standards were kept in mind to guarantee the highest level of safety. Diagnostic and fault messages are clearly visible. Pre-selecting of buckets protects against over-speeding. Steel armoured rotor chamber and lid lock system ensure safe operation. A key switch safeguards against unauthorized use. [*] GMP Centrifuges - The Cryofuge 6000i GMP (Good Manufacturing Practice) offers the same performance and accessories as the Cryofuge 6000i. The Cryofuge 8500i GMP attains a maximum centrifugal force of 8525 x g and a maximum speed of 5050 rpm. GMP Cryofuges are specially designed for use in clean room applications. [*] Data documentation - The Thermo Scientific HERANET data documentation system is available for data documentation in accordance with GMP. Safety Features: [*] Lid lock and interlock [*] Imbalance cut-ou [*] Steel armoured chamber [/list]
Height | 1178 mm |
Length | 800 mm |
Weight | 445 kg |
Width | 905 mm |
[list] Control and Drive: High performance induction drive, SEPACONTROL with microprocessor Acceleration and Braking Profiles: 9/10 profiles Temperature Control Range: -20ºC to +40ºC [/list]
