Thermo Scientific - HERAEUS Multifuge 3S Plus
Delivers unprecedented speed and capacity together with the widest range of rotors and adapters available.Supporting both research and clinical separation needs, our Heraeus Multifuge 3 Plus Series easily accommodates blood collection tubes, conical tubes, flasks, and microtubes, while four ultra-light carbon rotors allow you to process more samples more quickly than ever before - freeing you to focus on results.
FORUMSView All (6)
1Reply6 months ago | error 36 hello i have a problem with my heraeus multifuge 3sr when i start the machine its work properly if i stop it manualy there is no problem but when the machine stop on the time end an error apear on display error 36 anyone plz help me to solve tis issue. thanks in advance Reply |
1Reply6 years ago | Multifuge 3XR Hello we are having problems with our Multifuge 3XR and i was wondering if anybody would have access to a service manual for the unit. Thanks Reply |
3Replies6 years ago | Heraeus Multifige kepts tripping out Hello We have a problem with our Multifuge losing power. There is switch inside the unit that we need to reset to get the unit powered back on. Company techs believe that our power supply is the problem but to me this seems unlikely. Anyone has any advice Many thanks Reply |
Unmatched versatility, exceptional throughput - Nine swinging-bucket rotor configurations and seven fixed-angle rotors give the Heraeus Multifuge 3 Plus Series unmatched versatility, making it a cost-effective investment for any lab.
Unsurpassed productivity with high-capacity accessories - New carbon fiber rotors from FIBERLite® provide an advanced alternative to traditional metal rotors.
Enhanced user and sample safety - The SMARTspin® imbalance detection system allows for eye balancing of samples with automatic termination of a run if excessive imbalance occurs.
Modular, ergonomic design - The low deck height — just 31cm high — allows for easy loading and unloading of samples. The unique soft-touch lid effortlessly clicks into place for worry-free centrifugation.
User-friendly operation - The EASYset™ soft-touch keypad allows for one-touch control of speed, programming and pre-cooling functions.
Exceptional reliability -The brushless induction drive system guarantees years of dependable performance with minimal maintenance along with whisper-quiet operation and powerful acceleration and braking.
A bright, easy-to-read LED display allows easy monitoring from across the lab.
Automatic rotor recognition ensures precise rotor performance while preventing the use of incorrect accessories or parameters.
Lightweight and easy to handle, these rotors generate less wear on the centrifuge motor and are resistant to corrosion, fatigue and repeated autoclaving.
Spin up to 14 x 50 ml conical tubes in a single run.
Achieve superspeed performance with RCFs over 24,000 x g on the benchtop.
Safely perform high RCF, single-step separations using sterile, disposable conical tubes.
Rotor systems designed to handle up to 108 x 5/7 ml blood collection tubes, 28 x 50 ml conical tubes or 6 x 250 ml bottles in a single run allow you to achieve greater levels of productivity.
Maximum Speed | 4350 rpm |
Orientation | Benchtop |
Height | 14.3 in |
Length | 26.2 in |
Weight | 1 lbs |
Width | 21.7 in |
Control System: Digital Set-Point, Microprocessor; self-diagnostics
Acceleration/Deceleration: 9 rates
Programs: 4, direct keystroke access + pre-cooling program
Max RCF: 3700/4080 xg
Max Capacity: 4x750ml (120V/230V)
