Sorvall - Legend T/RT Plus
Thermo Scientific Sorvall Legend T/RT PlusThe Thermo Scientific Sorvall Legend T Plus and RT Plus Benchtop Centrifuge Series delivers unprecedented speed and capacity together with the widest range of rotors and adapters available for a premium three-liter centrifuge.
FORUMSView All (17)
2Replies4 months ago | error 30 Hi our machine has stopped working and displays the error e30 after looking through the manual, it says replace pcb, unfortunately, they are no longer made and the only ones i can find are in America from used machines. i have 2 questions 1, do you think its worth sending the pcb off to a company that repairs pcbs to see if it can be fixed (i have asked a few near me but they dont work on centrifuges) 2, if so, is the pcb the same as the main board, on the schematics, it looks like it is but in the instructions, it refers to main board and pcb seperately. many thanks and i appreciate any help Reply |
0Replies10 months ago | Nonsense characters The seven segment displays either have an "8" or a small "L" (upper left and middle segments), 1, 2, 3, 4, and the snowflake all have yellow lights. The unit has been powered off and on again. The manual mentions "display remains dark" and "display elements are shortly illuminated." I don't think either quite fits. Thoughts? Reply |
3Replies2 years ago | Sorvall - Legend T/RT Plus, Fisher Scientific accuSpin 3R Sorvall - Legend T/RT Plus, Fisher Scientific accuSpin 3R Power resets during fast brake with the buckets on the rotor. The control board has been replaced, same issue but now every time was intermittent. Reply |
[list] [*] Product Detail - Supporting both research and clinical separation needs, our Sorvall Legend T Plus and RT Plus Centrifuges easily accommodate blood collection tubes, conical tubes, flasks, and microtubes, while four ultra-light carbon rotors allow you to process more samples more quickly than ever before --freeing you to focus on results. [*] Unmatched versatility, exceptional throughput - Sorvall Legend T Plus and RT Series Benchtop Centrifuges offer industry-leading cpacity and performance for a three-liter tabletop centrifuge. Nine swinging-bucket rotor configurations and seven fixed-angle rotors give the Sorvall Legend T Plus and RT Plus Centrifuges unmatched versatility, making them a cost-effective investment for any lab. Rotor systems designed to handle up to 108 x 5/7 ml blood collection tubes, 28x50 ml conical tubes or 6x250 ml bottles in a single run allow you to achieve greater levels of productivity. [*] Unsurpassed productivity with high-capacity accessories - New carbon fiber rotors from FIBERLite® provide an advanced alternative to traditional metal rotors. Lightweight and easy to handle, these rotors generate less wear on the centrifuge motor and are resistant to corrosion, fatigue and repeated autoclaving. Spin up to 14x50ml conical tubes in a single run. Achieve superspeed performance with RCFs over 24000xg on the benchtop. Safely perform high RCF, single-step separations using sterile, disposable conical tubes. [*] Enhanced user and sample safety - Sorvall Legend T Plus and RT Series Benchtop Centrifuges: The next generation Legend in sample preparation. The SMARTspin® imbalance detection system allows for eye balancing of samples with automatic termination of a run if excessive imbalance occurs. Automatic rotor recognition ensures precise rotor performance while preventing the use of incorrect accessories or parameters. [*] Modular, ergonomic design - The Sorvall Legend T Plus and RT Plus Benchtop Centrifuge Series' low deck height – just 12” high -- allows for easy loading and unloading of samples. The unique soft-touch lid effortlessly clicks into place for worry-free centrifugation. [*] User-friendly operation - The EASYset soft-touch keypad allows for one-touch control of speed, programming and pre-cooling functions. A bright, easy-to-read LED display allows easy monitoring from across the lab. [*] Exceptional reliability - The brushless induction drive system of the Sorvall Legend T Plus and RT Plus Centrifuges guarantee years of dependable performance with minimal maintenance along with whisper-quiet operation and powerful acceleration and braking. [/list]
Orientation | Benchtop |
