Sorvall - Evolution RC
by Sorvall
Employing leading-edge technology, the Evolution RC offers unmatched productivity with a six liter capacity, speeds to 26,000 rpm, and simplified sample handling.
The Evolution RC offers shorter processing times with more throughput – and of course, maximum reliability. The unique DuoTherm system provides continuous, alternate heating and cooling to hold temperatures to within 2°C, even in standby. This not only prevents samples from freezing and chamber frost, but also eliminates frequent starting and stopping of the compressor – thereby extending compressor life.
2Replies4 years ago | Zaphod B. Scientific-Laboratory electronics engineer NZ Anyone ever had a motor drive assy issue whereby there is a motor enable and a run signal reaching the first pcb yet the lower drive module "enable" red LED is not turning on? The error message comes up in the display as "Tach signal not present" but this is only because the motor drive control module is not being "enabled" I'm guessing the fault s/w table isn't smart enough to isolate the fault any further? Don't want to have to purchase a new motor drive module as this is probably an smd logic ic fault on one of the motor drive pcb's which can easily be repaired. Any help will be greatfully reciprocated thanks Z Reply |
7Replies5 years ago | sensor offset error does not clear with Clear key Manual says this is a minor error and to simply clear it. The Clear key does not clear it. Please help. The machine was fine otherwize.Reply |
8Replies9 years ago | Power Fail error when I turn on the main switch on the monitor appear POWER FAIL error msg I need to do whant can I do to resolve this alarm thanks att raul Reply |
Fastest, easiest processing in the industry
Rotors and Accessories
Consistent performance, longer life
Easily accessible, hands-free rotor access
Height | 1295 in |
Length | 1055 in |
Weight | 860 lbs |
Maximum Speed | 26000 rpm |
Width | 710 in |
[list] Drive: Direct Brushless, DC Motor with DuraFlex™ gyro suspension Accel/decel rates: 3 acceleration, 4 deceleration Speed control accuracy: +0.2% or 20 rpm, whichever is greater Temperature control: +2 to +40 °C Temperature accuracy: +2 °C Ambient temperature range: 10 - 38 °C [/list]
