Thermo Scientific - KR25i
High speed, floor-standing centrifuge with lightweight accessories for research and large volume processing.The Jouan KR25i features guaranteed run-to-run reproducibility, absolute sample temperature control and accepts large sample numbers and volumes. Combined with the CQCS™ Network Quality Control System, the KR25i provides the ultimate in Traceability according to GLP, GMP, ISO9000 with full monitoring and search on samples, runs, machines and operators.
0Replies14 years ago | blood component can this centrifuge separate into its various components such as fresh frozen plasma, platelet concentrate, factor 8 rich plasma etcReply |
0Replies14 years ago | instruction manual instruction manual and service manual requiredReply |
[list] [*] SuperspeedHigh Security: JOUAN's patented AUTO-LOCK® ensures that the rotor is locked onto the drive at run start. At run end the rotor can be removed without tools. [*] Intuitive controls: VIDEOsetTM graphic control system with pictures, messages and graph of the run. [*] Full information: Display of all set and actual parameter values including speed, RCF, time, temperature, integral, rotor, radius, acceleration, and braking rates. [*] High precision: Microprocessor control of all parameters. [*] Lifetime reproducibility: Guaranteed run to run by automatic High Reproducibility Factor (integral). [*] True RCF: Using programmed radius allowing for use of adaptors. [*] Ideal for process development: 24 program memory. [*] Heat labile sample protection: Thin Film Technology (TFT) twin skin controls -8 to +40°C with easily 4°C at full load, full speed, any rotor. [*] Accurate temperature control: Patented temperature sensor and software independent of the bowl for better sample temperature control. [*] Convenient: Carbon fiber composite large volume rotors; half the weight of alloy rotors. [*] Space saving: Only 27” (69 cm) deep; can fit into a run of benches. [*] Simple installation: The rear foot can be lowered by a person standing in front of the machine. [*] Maintenance-free motor: Quiet, brushless induction motor, designed and manufactured by Thermo. [*] Absolute safety: Sealed buckets and microplate carriers certified to IEC 1010-2-020 for biocontainment by C.A.M.R. Porton Down. Imbalance detection and shutdown, guard barrier, dual lid interlock, current and temperature limitation. [/list]
[list] Max Samples: 6 x 500 mL, 6 x 250 mL, 14 x 50 mL, 8 x 50 mL con. Max Capacity - Swing-out: 400 mL = 4 x 100 mL - Fixed Angle: 3000 mL = 6 x 500 mL Max RCF - Swing-out: 27,200 xg - Fixed Angle: 63,400 xg Max Speed - Swing-out: 13,000 rpm - Fixed Angle 22,500 rpm HRF (integral): 100 to 998 x 10E9 Acceleration/Deceleration Rates: 10 rates Number of Memories: 32, individual password. [/list]
