Blickman - 7921TS
by Blickman
Blickman warming cabinets: the value leaders in the industry. These new and improved warming cabinets are ideal for heating and storing solutions or for warming blankets. Their open, adjustable shelving adds flexibility, while their fully self-contained design with internal heat vents make the cabinets more efficient and easier to operate. Easy-to-use controls located above the door set the internal temperature. All cabinets come standard with: glass or solid stainless steel doors, 90 ? 160 degree F temperature set range, visual and audible temperature alarms and an automatic safety cut-off, integrated casters on the 74 inch high models for easy mobility, built-in temperature data logger, (SD card records actual temperatures every hour), set temperature lock-out with both key lock and password lock, magnetic-gasket, adjustable tension, self-closing doors, keyed door locks, fully digital, numeric pad controller, both F and C displayed with one-touch toggle, no heat-rise between the compartments (in dual compartment models), finished backs, easy in-field door swing change, Energy Star efficient (pending), UL listed, CAN/CSA certified, OSHPOD certified. [b]Options include:[/b] sloping tops; mobile stand for table-top models; pass-thru capability; With all these features, plus the renowned "Blickman-Built" quality, you will be surprised at the affordability of these warming cabinets. Whether it is for the OR, PACU, ER or any other floor in the hospital, there is a style and size to meet your needs.
1Reply3 years ago | Lost password. Does someone know how to reset the password, the customer has forgotten/lost the password that they set.Reply |
[*] single-door warming cabinets [*] 74-1/2" tall [*] ideal for warming blankets or solutions. [*] An open and adjustable shelf design adds to flexibility and expanded use. [*] Easy-to-use controls for setting internal temperature are conveniently located. [*] Available with glass or stainless-steel door. Options include: sloping tops; mobile stand for table-top models; pass-thru capability;
Model Number 7921TS Part Number 14B7921200 Dimensions 30"W 26-5/8"D 74-1/2"H Ship Weight 437
