Blickman - 7925TS
by Blickman
Blickman warming cabinets: the value leaders in the industry.
These new and improved warming cabinets are ideal for heating and storing solutions or for warming blankets. Their open, adjustable shelving adds flexibility, while their fully self-contained design with internal heat vents make the cabinets more efficient and easier to operate.
Easy-to-use controls located above the door set the internal temperature. All cabinets come standard with: glass or solid stainless steel doors, 90 ? 160 degree F temperature set range, visual and audible temperature alarms and an automatic safety cut-off, integrated casters on the 74 inch high models for easy mobility, built-in temperature data logger, (SD card records actual temperatures every hour), set temperature lock-out with both key lock and password lock, magnetic-gasket, adjustable tension, self-closing doors, keyed door locks, fully digital, numeric pad controller, both F and C displayed with one-touch toggle, no heat-rise between the compartments (in dual compartment models), finished backs, easy in-field door swing change, Energy Star efficient (pending), UL listed, CAN/CSA certified, OSHPOD certified.
Options include:
sloping tops;
mobile stand for table-top models;
pass-thru capability;
With all these features, plus the renowned "Blickman-Built" quality, you will be surprised at the affordability of these warming cabinets. Whether it is for the OR, PACU, ER or any other floor in the hospital, there is a style and size to meet your needs.
Quality and control features are the same as those on the larger models.* An adjustable shelf comes standard.* suggested that these units sit on an existing cabinet, or on a Blickman transport dolly or mobile stand.* Easy-to-use keypad with controls for setting internal temperature is conveniently located above door.* Available with glass or stainless-steel door.
Options include: sloping tops; mobile stand for table-top models; pass-thru capability;
Model Number 7925TS
Part Number 14D7925200
Dimensions 30"W 26-1/2"D 24-1/2"H
Ship Weight 160
