Blickman - 7927TG
by Blickman
MODELS 7927TG is a warming cabinet that is compact in size for when space is at a premium.
MODELS 7927TG warming cabinet is 24-1/2" high and primarily used for warming solutions.
Blickman warming cabinets: the value leaders in the industry.
These new and improved warming cabinets are ideal for heating and storing solutions or for warming blankets. Their open, adjustable shelving adds flexibility, while their fully self-contained design with internal heat vents make the cabinets more efficient and easier to operate.
Easy-to-use controls located above the door set the internal temperature. All cabinets come standard with: glass or solid stainless steel doors, 90 ? 160 degree F temperature set range, visual and audible temperature alarms and an automatic safety cut-off, integrated casters on the 74 inch high models for easy mobility, built-in temperature data logger, (SD card records actual temperatures every hour), set temperature lock-out with both key lock and password lock, magnetic-gasket, adjustable tension, self-closing doors, keyed door locks, fully digital, numeric pad controller, both F and C displayed with one-touch toggle, no heat-rise between the compartments (in dual compartment models), finished backs, easy in-field door swing change, Energy Star efficient (pending), UL listed, CAN/CSA certified, OSHPOD certified.
Options include:
sloping tops;
mobile stand for table-top models;
pass-thru capability;
With all these features, plus the renowned "Blickman-Built" quality, you will be surprised at the affordability of these warming cabinets. Whether it is for the OR, PACU, ER or any other floor in the hospital, there is a style and size to meet your needs.
MODELS 7927TG
  • warming cabinets, compact size for when space is at a premium.* single-compartment counter-top warmers come standard with a glass door.* An adjustable shelf and stainless-steel door are available as options.* measures 20-1/8" deep, allowing for placement on most counter or table-top surfaces.* Unit is fully self-contained with no heat vents, as are all Blickman warmers.* more efficient and accuracy control
    Options include: sloping tops; mobile stand for table-top models; pass-thru capability;
Model Number 7927TG
Part Number 14B7927243
Dimensions 24"W 20-1/2"D 24-1/2"H
Ship Weight 161
