Esco Technologies - HPI-4P2
Isoclean® Hospital Pharmacy Isolator (Positive Pressure)Esco Isoclean Pharmacy Compounding Aseptic Isolator, provide a safe and clean environment for compounding of non-hazardous, sterile drug preparations and IV admixtures in compliance with USP 797 criteria. Barrier isolation system provide inherently superior sterility compared to open fronted clean air devices such as laminar flow clean benches and Class II biological safety cabinets. USP797 guidelines specify that isolators may be situated in an area subject to less severe environmental controls compared with open fronted clean air devices. When used as part of a system that includes operator aseptic technique training, process validation, expiration setting, product quality maintenance after the CSP leaves the pharmacy, isolators are a cost-effective solution especially for lower-volume pharmacies. They reduce operating and renovation costs, take up less space, and are easier to maintain. The Isoclean Pharmacy Compounding Aseptic Isolator is suitable for work involving non-hazardous materials. The work zone and pass-thru interchange are under positive pressure to the room in order to maintain sterility in case of a breach in the barrier isolation system. Negative pressure models should be selected for antineoplastic or cytotoxic compounding applications. [i]*United States Pharmacopoeia (USP), Chapter 797(1), enacted January 1, 2004, presents the first enforceable standards for sterile compounding. Following years of patient safety recommendations and professional guidelines, the intent of USP 797 is to set forth the procedural and practical requirements for safe compounding of sterile preparations. The Chapter's requirements are applicable in all practice settings where sterile preparations are compounded.[/i]
[list] [*] ULPA filters with a typical efficiency of 99.999% at 0.1 to 0.3 microns provide superior ISO Class 3 air cleanliness, 100 times better than competing products. [*] Sentinel Gold™ Microprocessor controller supervises all functions and monitors airflow and pressures in real-time. [*] Work zone and pass-thru are under negative pressure to the room in order to maintain operator protection in case of a breach in the barrier isolation system. [*] Robust dual-wall construction. The work zone is surrounded by negative pressure plenums at the sides and back. Unique Esco Dynamic Chamber™ plenum surrounds filter seals with negative pressure. [*] Ergonomically angled front and oval gloveports improve reach and comfort. [*] Safe-change cuff rings permit glove changes with zero risk of contaminating the work zone or pharmacy environment. [*] One piece work zone liner with no crevices is easy to clean. [*] Esco ISOCIDE antimicrobial coating on all painted surfaces minimizes contamination. [*] Sharps disposal system and hydraulic height-adjustable stand are available as options. [/list]
