Pulse Oximeter
PM-60 is a miniature, lightweight device capable of spot-check and continuous monitoring of SpO2 and pulse rate. PM -60 is a miniature, lightweight device capable of spot-check and continuous monitoring of SpO2 and pulse rate. You determine the capabilities and performance, depending on the operational mode you choose. For simple vital signs checks, spot-check mode offers basic functions including auto-assign of patient IDs, alarm suppression state and auto-standby and power-off features. For longer-term monitoring, continuous mode offers manual entry of unique patient IDs, alarm management and pleth waveform display. If pulse oximetry varies from day to day, or perhaps hour to hour, PM-60 is ideal as your device of choice.
- Spot Check Mode - auto-standby and power off during the idle status, auto-increase the patients IDs, non-alarm setting for “sensor off“ occasion 1-99 IDs for maximum 4,000 sets of measurements
- Continuous monitoring mode- regular alarm handing, enable to input patient ID manually, view SpO2 waveform for maximum 96 hours trend
- Suitable for adult and pediatric patients
- High resolution 2.4" colour LCD display
- Adjustable visual and audible alarms
- Real-time data transfer by infrared technology
- Choose between Lithium-ion or AA alkaline batteries (for up to 36 hours continuous working) depending on your run-time needs
- Protective cover perfect for portable monitoring needs
| Height | 120 mm |
| Length | 30 mm |
| Pulse Rate Range | 18-300 BPM |
| Weight | 300 g with battery |
| Memory | 96 hr |
| Operating Life | 24 hr |
| SpO2 Range | 0-100% |
| Width | 55 mm |
- Display: 2.4“ color TFT Resolution: 320 x 240
- Size: 55 x 120 x 30 mm
- Weight: 300 g with battery
- Multi dispays selectable: standard or waveform screen
- Trace: 1 plethysmogram waveform
- Indicator: alarm indicator light, power indicator light, pulse tone, alarm sound, button tones
- Interface: dual-purpose socket for connecting SpO2 sensor and communication cable IR interface: infrared link allows downloading realtime patient data to computer
- DC power interface: Charger stand for Li-ion battery
- DC power requirements: input voltage 5V DC Power 1.2A
- Battery: Li-ion battery 24 hours continuous working and 3xAA batteries 36 hours continuous working
- Trend memory: Monitoring mode: Resolution: 2s - Maximum time: 96 h
- Spot-check mode: Review of up to 4000 data, measure up to 99 patients
- Alarm: user adjustable high and low limits 3-level audible and visual alarm
