Mindray - PM-50
by Mindray
Pulse Oximeter
PM-50 is a miniature, lightweight device designed exclusively for spot-check monitoring of SpO2 and pulse rate. Weighing less than 200g, this device is easy to carry, easy to store, and equips you with just what you need to get the job done. Choose PM-50 and you will have the accuracy and efficiency you rely on when performing intermittent monitoring of a wide range of patients.        In addition, this powerful device is easy to maintain, requiring just four AA batteries for up to 15 hours of run-time. More convenience and ease-of-use mean more time to focus on your patients. Take the worry out of your spot-check monitoring routine and choose PM-50: the simple choice.
FORUMSView All (4)
-Ashe
Wed Feb 16 2022
Unable to read
How to fix plugged sensor not reading spo2Reply
-midavisdj
Fri Dec 12 2014
re: pulsoximeter don't turn on
pulsoximeter mindray pm 50 don't turn on. c16 and c89 warm up when I try to turn on. Any help?
-jpclemons
Wed Nov 30 2011
Troubleshooting PM-50
Trying to locate a manual for PM-50 to troubleshoot error messages.  When we turn the unit on, it just flashes with the ID number and no data.
SERVICE COMPANIESView All Pulse Oximeter Companies
  • Suitable for adult, pediatric and neonatal patients.
  • Convenient size and weight for spot check monitoring.
  • Automatic Standby and Power-off.
  • Stores up to 100 patient IDs and 200 measurements.
  • Data transfer to PC for storage or printing.
  • Convenient AA size alkaline or rechargeable batteries.
  • 3-Year manufacturer warranty on main unit!
Height5.51 in
Length 1.26 in
Pulse Rate Range25-254 BPM
Weight29 lbs
Operating Life15 hr
SpO2 Range0-100%
Width2.56 in
  • Adult, Pediatric and Neonatal.
  • Type: Backlit LCD.
  • Parameters: SpO2;PR.
  • Status: Standby; Communication; Download.
  • Information: Patient ID; Indicator of data storage;/Low power; Pleth Bar; Error; Standby.
  • Type: 4AA Alkaline batteries of 4AA rechargeable batteries.
  • Life: approximately 15 hours for normal measurement status.
  • Type of Protection: internally powered equipment.
  • Degree of Protection: BF.
  • Safety: IEC 60601-1, EN 865, ISO 14971.
  • Com Port: RS-232.
  • Auxiliary Software: record management and data printing through PC.
