Thermo Scientific - Centra W Cell Washer
Precise, automated performance for blood cell washingSimplify work and reduce time required to wash blood cells with the advanced, easy-to-use Thermo Scientific Centra W Cell Washer.
The Centra W is the clear choice for trouble-free automation of washing steps for antiglobulin testing. Set all steps of your wash cycles just once and operate the unit by simply loading the rotor, shutting the cover and pressing the start key. The flawless results are clean, dry cell buttons every time.
2Replies8 years ago | Sorvall CW2 will not decant Anyone seen this problem of not decanting. Spins at 3550 great and replaced the control board. Feel the motor vibrating during decant , but does not move.. can hear relay click when need to decant. No RPMs Reply |
1Reply11 years ago | re: Service manual Reply |
- Fully Automated for Reproducible Results
- Easy, Reliable Operation
- Compact and Durable
- Automatic Mode and Manual Mode
- Maximize Antiglobulin Reagent Reactivity
- Complete Automation for Increased Productivity
- Eliminate Cross-Contamination
- Use Standard Tubes
- Low Saline Detection
- Agitate Cycle
- Easily Check System Steps
- Easy to Clean
Height | 15.2 in |
Length | 17.1 in |
Weight | 17.8 lbs crated, 15.4lbs uncrated |
Maximum Speed | 3550 rpm at 60 Hz |
Width | 12.6 in |
Cycle Time: 80 seconds
Tube Dimensions: 10 x 75 mm 12 x 75 mm
Spin Speed: 3550 rpm (60 Hz) 2950 rpm (50 Hz)
Fill/Decant Speed: 700 rpm (60 Hz) 580 rpm (50 Hz)
Display: LED
