Thermo Scientific - CL10
by Thermo Scientific
The perfect solution for your low-speed clinical applications.
Designed for everyday use, the CL10 offers many innovative features that make it the most complete basic centrifuge available. Its compact, space-saving design delivers reliable separations quickly and safely, making it the ideal centrifuge for small and medium laboratories and medical offices.
FORUMSView All (6)
-LUIS BAEZ
a year ago
MANUAL
HOW CAN I GET THE MANUAL OPERATION OF THE CENTRIFUGE CL10
Equipment: CENTRIFUGE CL10
-hscscientific1_4433
5 years ago
Display [rob;em
Hi I have a Thermo CL 10 centrifuge. When I turn it on it powers (I can hear a buzzy noise) but no display . I did check the fuses 9they are ok). Any suggestions ? Regards HermannReply
-Ashier
8 years ago
Blown Powr Suply board
I would like to know whether I can get a replacement for the blown power supply board for the mentioned centrifuge model CL10. And where can i get it here in Uganda. Thank you. I remain Segane Ashirae. Biomedical Enginer Kabale Hospital - Ukanda
[list]  [*] Fast, Efficient and Reliable, spins 6 different swing-out and fixed angle rotors, up to 16x5/7 ml vac and 6x50 ml conical, with minimal sample temperature increase and very low noise  [*] Convenient and Functional, due to the user-friendly interface–with its bright, easy-to-read digital display, the brushless induction drive, the compact design and the high-quality manufacturing materials  [*] Safe, thanks to the aerosol-tight accessories, tested by CAMR Porton Down, the automatic imbalance detection, the automatic rotor recognition, the CE mark and the compliance to the most rigorous worldwide regulations and European directives.  [/list]
Height11 in
Length 18.1 in
Weight61.7 lbs
Maximum Speed4000 rpm
Width14.6 in
Control System: Digital Set-Point, Microprocessor; self-diagnostics      BTU Output: 512/h
