Iris Diagnostics - iChem 100
The most productive semi-automated analyzer on the market today.The new iChem™100 semi-automated urine chemistry system is designed to perform like no other urinalysis system. It's the instrument solution that eliminates the tradeoffs between performance and value. And it's manufactured by the leader in complete urinalysis, Iris Diagnostics, for unmatched quality and accuracy.
0Replies9 years ago | Control Can you use a different brand of controls to control the iChem, for example could i use Clarity Controls for a iChem machine. Reply |
0Replies11 years ago | Hematology Supervisor I worked with an older Iris at University of Tennessee in Knoxville from 2001-2003. I found it tricky to distinguish bacteria from amorphous with out the "movement" factor. Has the new model improved on this? Linda Lloyd Reply |
[list] [*] Enhanced Lab Productivity [*] Data Entry [*] Connectivity [*] Large Patient Storage [*] Manual Entry of Microscopic Data [*] Confidence in Results [*] Internal Calibration Verification [*] Interference Detection Capability [*] Automated QC Analysis [*] High Degree of Specificity [*] Ease of Use [*] Multiple Data Entry Options [*] Multiple Languages [*] Three Step Process [*] Minimal Maintenance [/list]
• Tests Performed: 13 (10 Urine Chemistries, Specific Gravity, Color and User Defined Clarity) • Test Strip: iChem™ 10 SG Urine Chemistry Strips • Sample Throughput: 210 samples per hour • Display: 8 Lines / 40 Character LCD • Printer: Built-in thermal printer • Data Storage: 2,000 results, 300 controls • Computer Interface: RS-232 • Operating Environment: Temperature: 15°–32°C (59°– 90° F) Humidity: 20 – 80% non-condensing • Power Supply: 100 to 240 Vac, 50 to 60 Hz • Dimensions: 28H x 50W x 25D cm (11H x 20W x 10D in) • Weight: 7.5 kg (16.5 lbs.)
