Roche - Criterion II
by Roche
Urine Analyzer
The CHEMSTRIP Criterion II Urine analyzer is an easy-to-operate, semi-automatic urine analyzer that ensures accurate results, test after test. It maximizes your lab efficiency by reducing hands on operator time. And its convenient, compact design makes it an ideal fit for work areas large or small.
FORUMSView All (5)
-enordhoff
10 years ago
Calibration errors
Each calibration comes off with an error, usually cal error 74. What is my next step?
-Carmen Marie
11 years ago
Host communication set up
How do you access the screen where you set the host communication items? Baud Rate, Parity, Stop Bits; Bits?
-steve13
12 years ago
Power Requirements
I have seen no information for required voltage and amps.  Do you know what is required?
  • Automatic transmission of results to host PC after each sample is run
  • Automatic color determination
  • Continuous sample processing (throughput of 100 tests per hour)
  • Optimized for 15-75 tests per day
  • Calibration required only once every 14 days
  • Memory capacity for 150 results
  • Compact size
