Roche - URISYS 1800
by Roche
Urine Analyzer
With proven CHEMSTRIP® accuracy, the URISYS 1800® Urine Analyzer delivers the most convenient, easy-to-use urinalysis testing solution for your hospital. Simply unpack the instrument, plug it in, and you're set to improve your urinalysis work flow. This semi-automated unit runs fast — just a 6-second cycle time — so you can load strips continuously at a pace you determine. Plus, customization options let you define result flags, create specific reports, and choose the right connectivity.
FORUMSView All (11)
-BBasketball40
Tue Feb 01 2022
PartRoche
Hello. Does anyone know how to order a part for this machine? I have a broken paper holder that I need to replace. Thanks, BBReply
2
-KCC MLT Program Director
Tue Sep 01 2020
Operator Manual
Can I get a copy of the Urysis 1800 Operator's Manual?Reply
2
-Toni Z
Tue Jul 14 2020
urisys 1800
looking for a manualReply
  • Easy to Operate
  • User-friendly operation - simply dip and insert the urine test strip
  • Save time with automatic transmission of results to Host PC after each measurement
  • Flexible entry of sample ID with barcode scanner or alpha-numeric keypad
  • Complete test parameter menu
  • Specific Gravity, Leukocytes, Bilirubin, Urobilinogen, Glucose, Ketones, Protein, pH, Blood, Nitrites, and Urine Color via test strip.
  • Risk-free color interpretation
  • Ensure consistency of results with automatic color measurement
  • Programmable setup options include 8 color determinations
  • Reduce false negative results and the need to retest
  • Virtually eliminate Vitamin C interference for blood and glucose
  • CHEMSTRIP technology consistently measures both acetoacidic acid and acetone
  • Attractive Software Features
  • Touch screen display with clearly arranged software functions
  • Positive sample identification via barcode scanner
  • Result memory for 1000 samples and 300 control samples
  • Various flagging options for sample and control results
  • Bi-directional serial interface for host communication
  • Easy system calibration using special calibration strips
  • Minimal operator time for calibration and maintenance
  • Calibration required only once every 4 weeks
  • Daily maintenance takes less than 1 minute
  • Throughput- 600 test strips per hour
  • Measuring System- 1 measuring head with 20 LEDs
  • Wavelengths: 470nm, 555nm, 620nm
  • Sensors: 11 wide range photosensors
  • Reading time: 60 seconds
  • Data memory capacity: Routine:1000 samples
  • Control: 3 level x 100 samples
  • Power Supply 100 – 240 V (50/60 Hz) external universal power supply
  • Maximum power consumption: 75 VA     Fuse: 2.5 AT
  • Dimension-  Width: 16.3 inches  Depth: 13.4 inches  Height: 14.2 inches
  • Weight-  24.3 lbs.
