Siemens - CLINITEK Advantus; Analyzer
by Siemens
Urine Analyzer
Respond to demands for higher productivity and high quality with the newest addition to the Clinitek family, the Clinitek Advantus analyzer. Streamline your workflow with flexible operation. Immediate start-up. Automatic calibration. Network ready. Widest range of test options. Added QC features. Flexible operation to meet your needs.
3RepliesThu Jul 30 2020 | Lamps needed We are in need of replacement lamps used in the sample chamber of this unit. The part number of the bulbs is 10310889. Does anyone know where can get one. The start is no longer available from Siemens. Reply |
1ReplyFri May 29 2020 | Light Bulbs Needed Does anyone know the part number and where I can purchase replacement lamps for this Clinitek Advantus? It uses two 6 volt 200 MA lamps. The number OL3288LX is stamped on the bulbs. Reply |
1ReplyThu Feb 21 2019 | QC Failure Always got positive on Nit while running negative control. It should be negative (nit) on the negative control. What could be the problem on the equipment side.?Reply |
| Height | 12.75 in |
| Length | 13.75 in |
| Weight | 35 lbs |
| Width | 15.75 in |
