Siemens - ADVIA 2120
by Siemens
Hematology Analyzer
The ADVIA 2120 and ADVIA 2120i Hematology Systems are fully automated analyzers that perform Complete Blood Counts with Differential, Reticulocyte analysis and Two-dimensional Platelet analysis using a combination of Laser Light Scatter and cytochemical staining, providing higher confidence and better efficiency. CSF analysis reduces manual operator intervention and improves turn around time. In addition, Flexible sampling modes and onboard reagents allow you to maximize your precious resources: blood, operator safety, workspace, and storage areas. The ADVIA® 2120 Hematology System gets the job done and gets it right the first time, with a review rate far lower than competing systems.
FORUMSView All (7)
-jmcgw
7 years ago
RBC data
I've been told that we are to report out the RBC interpretations (Hypo, hyper, aniso, etc) from the Advia 2120 instead of what is seen when doing slide reviews and manual differentials. Has the analyzer been approved for this? Is it truly better than the human eye in reporting?Reply
-Engineer Khaleeque
8 years ago
NEED pm CHECK LIST
I NEED PM CHECK LIST FOR ADVIA 212I
-hamza.kifouche10@gmail
9 years ago
communication
structure of message advia 2120
principe d'echange et de communication port serie
  • ADVIA 2120 and ADVIA 2120i technology utilize Peroxidase stain, the gold standard for WBC differentials, therefore, delivering better agreement with your technologists’ manual results- providing higher confidence, better efficiency.
  • True RBC morphology advances cell separation to a new level that allows for the differentiation of various disease states, including those associated with anemia.
  • Maximize the effectiveness of costly platelet transfusions with accurate results the first time, every time - even at very low platelet levels. Two dimensional optical platelets analyze both extra-cellular and intracellular properties, ensuring that large platelets are included in your counts, and known interferences are not.
  • Rack-based capacity for 150 samples delivers all the benefits of "walkaway" convenience.
  • Fixed throughput of CBC/Diff at 120 samples per hour, even on leukopenic samples, provides fast results reporting to enhance the service to clinicians.
  • Proven technology, reference methods and onboard delta checks reduce manual slide reviews.
  • Increased linearities minimize costly, timeconsuming dilutions and repeat.
  • Differentiates microcytic anemias with advanced RBC and reticulocyte technology.
  • Automates hematology workflow without the need for large track-based systems, expensive stains, or reflexive testing.
  • Delivers gold standard flow cytometry peroxidase methodology for optimum results.
  • Simplifies maintenance through reduced fluidics, eliminated pinch valves, and automated daily cleaning using Unifluidics™ Technology.
Height33.8 in Analytical Module with Autosampler
Length 26.8 in Analytical Module with Autosampler
Weight425 lbs Analytical Module with Autosampler
Width55.5 in Analytical Module with Autosampler
  • 150 Sample Capacity: 15 Racks with 10 tube capacity
  • Compatible Tube Types: VACUTAINER®, HEMOGARD®, Monovette®, Venoject®II, Venosafe®, Vacuette®, Monoject®
  • Bar Code Reader: Up to 14 digits
  • Automatic discrimination of label codes: Codabar
  • Interleave 2 of 5 with and without check digit
  • Open Tube 175µL.
