Horiba Medical - Pentra 80
by Horiba Medical
Hematology Analyzer
Autoloader with continuous loading capability. STAT sampling on open and closed tube. Microsampling from whole blood (CBC : 30 µL - DIFF: 53 µL) Automatic Sample Re-run. Integrated workstation with LCD-color touch screen. Windows NT MDSS* technology. DHSS* technology
-Evilenko
Wed Jun 27 2012
No LMNE throughput
Good evening.
I have a problem reading  into the determination of the blood population. Same problem in two instruments: pentra 80 and 60. I can obtain all values except the LMNE value. All to zero in the Pentra 80 , and 99.7~ LYN in the pentra 60. I have checked all tubes, valve, syringe, everything. But i can not find where the fault is generated.  Can someonehelp me ?
I don't have the RBC/PLT latex to test the absorbance and resistivity.
Thanks in advance
-Wayne B.
Sun May 13 2012
service
I need to reset the mixer motor values but dont remember the service password on a pentra 80
  • Ideal for "hot lab" working
  • Integrated Workstation with Color Touch Screen
  • Micro-sampling from whole blood (CBC : 30 µL - DIFF: 53 µL)
  • Cytochemistry, Impedance (real cell volume measurement) & Optical (analysis of the internal cellular structure by measuring light absorbance) - DHSS* Technology.
  • Perfect homogenization of blood samples with reagents - MDSS** Technology.
  • Throughput: Up to 80 samples/hou
  • Large capacity auto-loader (100 tubes)
  • Stat sampling on open or closed tubes
  • Automatic Sample Re-run
  • Reagents: Only 4 onboard reagents and 1 diluent
  • Perfect differentiation of the 5 WBC sub-populations with DHSS* Technology
  • 3 histograms for RBC, BAS/WBC and PLT together with the 5 DIFF Matrix.
  • Basophils counted through specific channel
  • High resolution matrix includes the determination of 2 additional subpopulations (% and #): Atypical Lymphocytes (ALY***) and Large Immature Cells (LIC***)
  • * DHSS : Double Hydrodynamic Sequential System (HORIBA Medical Patent)
    ** MDSS : Multi-Distribution Sampling System (HORIBA Medical Patent)
    *** RUO parameters (Research Use Only)
