Horiba Medical - ABX Pentra 80
by Horiba Medical
Hematology Analyzer
High performance hematology analysis with integrated validation.
-sharifu
8 years ago
No working properly
Print out startup hgb blafailledhgbout of limit. Platelets failedReply
  • 27 parameters
  • Whole blood micro-sampling (CBC: 35 µL, Plus Diff 53 µL)
  • Cytochemistry, Impedance (real cell volume measurement) & Optical (analysis of the internal cellular structure by measuring light absorbance) - DHSS* Technology
  • Perfect homogenization of blood samples with reagents - MDSS** Technology
  • Automatic Sample Re-run
  • Reagents: Only 4 reagents plus cleaner
  • Perfect differentiation of the 5 WBC sub-populations with DHSS* Technology
  • 3 histograms for RBC, BAS/WBC and PLT together with the 5 DIFF Matrix
  • Basophils counted through specific channel
  • High resolution matrix includes the determination of 2 additional subpopulations (% and #): Atypical Lymphocytes (ALY) and Large Immature Cells (LIC)
  • Customized Dilution Ratio (CDR)
  • Integrated Workstation and Validation Station
  • Weight 122 lbs, 55 kg.
  • Power supply 100/240 V - 50/60 Hz - 300 VA.
  • Dimensions 32.3 x 22.4 x 21.5 (H x W x D) in, 82 x 57 x 54 (H x W x D) cm.
  • Printer
  • Laser
  • Throughout 80 samples/hour.
  • Data processing
  • Windows NT 4.0 Floppy Disk & CDROM reader, RS232C, Mono and bi-directional connection.
  • Memory capacity 10 000 results + graphics
  • Samples 80 samples/hour (open or closed tube)
  • Parameters (26) WBC, RBC, HGB, HCT, MCV, MCH, MCHC, RDW, PLT, MPV, *PCT, *PDW % and # NEU, LYM, MON, EOS, BAS
  • Plus  *ALY = Atypical Lymphocytes (% and #) *LIC= Large Immature Cells (% and #)
  • Graphs High-definition LMNE color matrix PLT, RBC, WBC/BAS curves
  • Volume  CBC mode : 30 µL CBC + DIFF mode : 53 µL
  • Stability  48 hours
  • Operating sample mode
  • Autoloader 10 racks (100 tubes) capacity
  • Sample mixing with end-over-end tube rotation
  • Closed or open STAT tube
  • Identification Alphanumeric / Bar-code reader (internal and external) RUO (Research Use Only)
