Horiba Medical - ABX e-Sat
Hematology Analyzer
Specially designed for clinics, laboratories and emergency services, this ABX e-SAT external module contains all the functions needed to manage results securely and easily from local or remote locations The interface of the ABX e-SAT prides itself on a perfect combination of technology and user-friendliness.More than simply multi-functional, its elemental design allows its users to dedicate more time to lab activities rather than technical operation.
0Replies5 years ago | lost access password Good morning technicians, Unfortunately I lost password to access to the abx e-sat module. Can someone tell me how to reset this password? ThanksReply |
- Touch screen interface
- Printer
- Barcode reader
- Front USB port to archive data with easer
- User identification
- Patient identification by barcode or keyboard input
- Quality control management (results and time interval QC)
- Reagent management (expiration and volume)
- Optimized presentation of results to accommodate various clinical environments
- Search and display engine for 1000 archived results
- 1000 patient results
- Built-in search engine
- Exportable data (USB key)
- Parameters (16 + 2)
- CBC Mode (18 parameters): WBC, RBC, HGB, HCT, MCV,*RDW, MCH, MCHC, PLT, MPV, PCT, *PDW, % and # of LYM, MON and GRA
- Graphics : LMG histogram, RBC, PLT histograms
- Sample-Volume : CBC mode : 10 µL
- Stability : 24 hours (CBC)
- Operating sample mode : Open tube mode with 4 position tube holder (QC, 125 or 500 µL, 3 or 5 mL)
- Identification : Patient I.D., Sequence#
- Flags : Pathological flags (WBC, RBC, and PLT) normal limits and counting failure flags RUO (Research Use Only)
- Weight 8.8 lbs
- Power supply AC input voltage 100 VAC to 240 VAC (± 10%) / AC input frequency - Nominal: 50 Hz to 60 Hz (± 5%) / Power consumption maximum 150 VA
- Dimensions 7 x 7.7 x 10.4 inches (H x W x D)
- Hardware 8.4 TFT LCD screen w/LVDS* interface 256,000 color, 640x 480 pixel resolution
- Inverter card for LCD screen
- Touch screen technology
- Secure digital memory card: 256
- Built-in barcode reader 58mm thermal printer with rapid paper loading
- External power block Linux
- Operating System
- Low voltage differential signaling
