Getinge - 5624
by Getinge
Designed for the warm storage of saline solutions and/or blankets used in surgery, recovery, OB/GYN, ICU or ER
A unique warming cabinet with "look-in" tempered glass doors into two separate, independently controlled, convection heated chambers. Temperature range in each compartment is adjustable from 90°F (32°C) to 160°F (71°C) and is provided with a "lock-in" feature to prevent unauthorized changes to the temperature settings.
FORUMSView All (28)
-kdiehl
Wed Sep 24 2025
Fan and Heater access
Removed screw on upper compartment for heater fan access. What's the trick to getting the cover off?
-Unity Point Health
Wed Mar 27 2024
fan parts
trying to order fan parts for Getinge 5624 serial # J064108
Equipment: j064108
-ECHO LAB
Fri Oct 06 2023
need manual
Need manual or PDF file of instructions
Equipment: Getinge 5624
[list]          [*] "Look-In" glass doors provide visual inventory control without opening doors          [*] Large useable internal volume for storage of solution bottles and blankets          [*] Forced air convection heating is more effective and eliminates the need for blanket racks          [*] Independent heat control provides flexibility of different temperatures in each compartment          [*] Programmable for °F and °C display          [*] Supervisory "Lock-In" of temperature set point prevents unauthorized changes of temperature          [*] Non-volatile memory protects temperature settings in the event of a power loss          [*] An LED display will alert operator of an interruption or power loss          [*] Overheat protection will shut the heaters off and provide an audible alarm for the operators          [*] Adjustable shelves provided to accommodate various types of loads          [*] Mounting options include floor mounted on a pedestal base, wall mounted or recessed in a wall          [/list]
Height60 in
Length 24.7 in
Width30 in
Interior Dimensions:          - Upper: 26" W x 13" H x 22.7" D             - Lower: 26" W x 40" H x 22.7" D          Capacity:             - Upper Compartment volume: 4.1 ft3; 20 two-liter flasks or equivalent dry goods        - Lower Compartment volume: 13.4 ft3; 60 two-liter flasks or equivalent dry goods
