Horiba Medical - ABX Micros CRP
by Horiba Medical
Hematology Analyzer
The HORIBA ABX Micros is a fully automated hematology analyzer used for in-vitro diagnostics testing of whole blood specimens, platelet PRP samples, and whole blood component concentrates. The HORIBA analyzer uses impedance technology and photometry as measurement methods, as well as stepper motor technology which enables the system to operate without a compressor.
-Robi
Sat May 05 2018
Service manual, user manual
Hi, I would need service manual and user manual for hematology analyzer Horiba Medical - ABX Microsemi CRP. Thank you for great support. Reply
  • Compact, three-part differential
  • Eight or 18 parameter
  • 60 Samples/hour (open tubes), 55 samples/hour (closed tubes)
  • 100% “hands-free” open/closed sampling system
  • Automatic sample probe cleaning and rinsing
  • No compression, no pinch valves
  • Variable sized tube holder accepts almost any type of tube, including those used from fingerstick collection devices
  • Weight 18 kg.
  • Power supply 90/240 V - 50/60 Hz - 150 VA.
  • Dimensions 41 x 30 x 40(HxWxD) cm.
  • Printer 80 column dot matrix printer.
  • Throughout CBC Mode : 50 tests/hour. CBC & CRP Mode : 15 tests/hour
  • Samples Parameters (18 or 19) CBC Mode (18 parameters): WBC, RBC, HGB, HCT, MCV, RDW, MCH, MCHC, PLT, MPV, PCT, PDW, % and # of LYM, MON and GRA CBC & CRP Mode (19 parameters): CBC + CRP
  • Graphics LMG histogram, RBC, PLT histograms
  • Sample-Volume CBC mode : 10 µl CBC & CRP mode : 18 µl
  • Stability 24 hours (CBC)
  • Operating sample mode Open tube mode with 4 position tube holder (QC, 500 µl, 3 or 5 ml)
  • Identification Patient run number
  • Flags Pathological flags (WBC, RBC, and PLT) and normal limits
