Hematology Analyzer
Belonging to the Micros family presented by Horiba Medical, the Horiba Micros CRP200 is a 3 part differential benchtop hematology analyzer boasting 17 assays with a maximum throughput of 75 tests per hour. The system is an easy to use, robust, easy to use, open reagent system.
- Power supply from 100 Vac to 240 Vac +/- 10% 50 Hz to 60 Hz.
- Power consumption Maximum 230 VA.
- Operating Temperature and Humidity : 18°C - 30°C (64°F-86°F) room temperature.
- Maximum relative humidity 80% for temperature up to 31°C (88°F) decreasing linearly to 50% relative humidity at 40°C (104°F).
- Weight : 40 lbs
- Dimensions : W 11.8 x H 16.7 x D 15.7 in
- QC (CBC) and QC (CRP) modes: 30 samples CBC and CBC+CRP modes: 50 samples
- Parameters CBC mode 18 parameters with graphics for RBC, PLT and WBC populations. RBC, WBC, PLT, HGB, HCT, MCV, MCH, MCHC, PCT, MPV, PDW, RDW, Lymphocytes (% and #), Monocytes (% and #), Granulocytes (% and #). CBC & CRP mode 18 parameters & CRP
- CBC mode : 10 µl CBC & CRP mode : 18 µl
- Measurement itemWBC, RBC, HGB, HCT, PLT, CRP (C-reactive protein) MCV, MCH, MCHC, RDW, MPV, LYM%, LYM#, MON%, MON#, GRA%, GRA#, PCT*, PDW*.
- Sample processing On open tube with 4 position tube holder (QC, 500 µL, 3 mL, 5 mL)
- Throughput analyses CBC mode: Within 1 min, 15-sec (48 samples/hour) CBC + CRP mode: Within 4min, 30-sec (14 samples/hour) *: RUO parameters (Research Use Only)
