Thermo Scientific - Shandon Cytospin 4
Thermo Scientific Shandon Cytospin 4The Shandon Cytospin has been synonymous with cytocentrifugation for over 35 years. More than 15,000 laboratories worldwide use this simple, reliable instrument. It provides economical thin-layer preparations from any liquid matrix, especially hypocellular fluids such as spinal fluids and urines.
Synonymous with cytocentrifugation for over 40 years, this reliable instrument is used in more than 15,000 laboratories worldwide. It provides economical thin-layer preparations from any liquid matrix, especially hypocellular fluids such as spinal fluids and urines.
FORUMSView All (11)
1Reply2 years ago | imbalance error how pull out the rotor?Reply |
4Replies4 years ago | error 3 does enyone know how to solve that ? user manual didn 't explain too much cytospin 4 thermoscientifc Reply |
2Replies7 years ago | need operators manual need operators manual Reply |
- Auto-locking, plastic outer lid
- Autoclavable Sealed Head
- Disposable sample chambers with caps
- Safety alarms that protect users and specimens
- Wipe-clean control panel
Features - Process 12 specimens at one time
- Accepts all protocols from Shandon Cytospin 1, 2, and 3
- Redesigned Lid-release Mechanism allows for one-handed opening and closing of the outer lid for easy access
- Excellent safety design prevents accidental fluid spillage from damaging the mechanical or electronic components and allows for easy disinfecting
- Pull-out Program Card allows for up to nine programs to be logged for fast and convenient retrieval (erasable ink pen included)
Shandon Cytospin Sealed Head - One Sealed Head is included with the Cytospin, but many laboratories shorten preparation time by having a second Sealed Head ready for when the first finishes processing
- Autoclavable, 12-chamber Head seals completely
Simple and Precise Controls - Protected Program Memory stores up to 23 routines for instant recall and protects from power loss
- Program Key Pad has “easy-touch” design that allows for easier keystrokes and more intuitive programming
- Speed window displays the programmed spinning speeds from 200 – 2000 rpm
- Three Acceleration Control buttons allow the operator excellent flexibility and exceptional protection for fragile samples
- Time window displays the programmed and remaining run time from 1– 99 minutes
- Control feature has a standby power saving mode. Displays are also turned on and off by the standby key
Safety Alarms - Audible alarm that signals the operator if the Shandon Cytospin Cytocentrifuge is out of balance, outside the speed tolerance, or if the lid is not properly locked. As an extra measure of safety for the user, the unit will not spin if the lid is not locked
- Specimen safety alarm feature has been added to remind users at one-minute intervals to remove specimens, protect them from “air-drying” and ensure consistent results
Safe and Reliable
Height | 9.5 in with closed lid |
Length | 24.5 in |
Weight | 26.5 kg |
Width | 16 in |
