Mindray - WATO EX-65
Maximum technical performance, contemporary and ergonomic design, closed with the latest modern anesthesia concept.The WATO EX-65/EX-55 is designed for ease of use, incorporating the maximum patient safety in daily anesthesia practice. A small footprint and compact size is appropriate for any environment where space is limited.
FORUMSView All (5)
2Replies2 years ago | Encoder The encoder movement key of the wato ex 65 device works but does not confirm its inputs. it only works in directions. I changed the encoder but the problem did not go away. can you help me?Reply |
1Reply9 years ago | aNESTEZ? C?HAZI KONTROL PANEL? F?YAT ?STEM? ?Y? GÜNLER YUKARDAK? BEL?RT?LEN ÜRÜNE UYUMULU ANESTEZ? KONTROL PANEL? ?HT?YACIMIZ BULUNMAKTADIR BUNUNLA ?LG?L? F?YAT TEKL?F? VER?LMES? HUSUSUNDA GERE??N? B?LG?LER?N?ZE SAYGILARIMIZLA ARZ EDER ?Y? ÇALI?MALAR D?LER?Z. MELSAN T?CARET Mehtap TOKSÖZ Tel : 0216 489 46 00 Fax :0216 489 63 92 Gsm : 0533 310 02 75 Reply |
2Replies10 years ago | Don´t have manuals Anesthesic machine MINDRAY WATO EX-65
Reply |
[list] [*] Breathing circuit with CO2 bypass valve, which supports CO2 absorbent canister exchange during surgeries [*] Informative message displayed on screen to confirm the assembly of CO2 absorbent canister [*] Cardioplumarybypass (CPB) alarm management [*] Multi-selectable display on a TFT screen [*] Contemporary and ergonomic consideration [*] Electronic flowmeters of O2, N2O or Air [*] Electronically-controlled and pneumatically-driven ventilator [*] Allow in conjunction with up to 2 vaporizers [*] Minimum TV down to 20mL, suitable for the patients from neonate to adult without changing the breathing circuit. [*] Modular device of EtCO2, Anesthetic Agents, BIS and loops measurement [/list]
Height | 53.3 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 24 in |
Vaporizers (Max) | Two |
Weight | 266 lbs |
Vaporizer Type | Electronic control |
Vent Modes | VCV, PCV, SIMV, PSV and Manual modes |
Width | 27.6 in |
