Getinge - 5524
The Getinge 5524 Warming Cabinet is designed for the warm storage of saline solutions or blankets used in the care of patientsThe Getinge 5524 Warming Cabinet is designed for the warm storage of saline solutions or blankets used in the care of patients in areas such as surgery, recovery,OB/GYN, ICU or ER. A unique table top warming cabinet with a "look-in" tempered glass door into its convection heated chamber. Temperature range is adjustable from 90°F (32°C) to 160°F (71°C) and is provided with a "lock-in" feature to prevent unauthorized changes to the temperature setting.
FORUMSView All (8)
2Replies4 months ago | Overheating OH error, where to start in replacing parts. Reply |
1Reply4 years ago | Looking for user manual for 5524 Castle warmer Just looking to download a copy of the Castle 5524 blanket warmer user manual. Thanks, Steph HannahReply |
1Reply5 years ago | SERVICE MANUAL ANYONE KNOW WHERE TO FIND A SERVICE MANUAL FOR A GETINGE 5524 CABINET WARMER...I NEED TO FIND OUT HOW TO TAKE BACK PANEL OFF....Reply |
- "Look-In" glass doors provide visual inventory control without opening doors
- Large useable internal volume for storage of solution bottles and blankets
- Forced air convection heating is more effective and eliminates the need for blanket racks
- Independent heat control provides flexibility of different temperatures in each compartment
- Programmable for °F and °C display
- Supervisory "Lock-In" of temperature set point prevents unauthorized changes of temperature
- Non-volatile memory protects temperature settings in the event of a power loss
- An LED display will alert operator of an interruption or power loss
- Overheat protection will shut the heaters off and provide an audible alarm for the operators
- Adjustable shelves provided to accommodate various types of loads
- Mounting options include table top, wall mounted or recessed in a wall
Dimensions Exterior: 30'' (762mm)W x 17.5'' (445mm)H x 24''.7 (610mm)D Interior: 26'' (660mm)W x 13'' .5(330mm)H x 22.7'' (577mm)D Capacity Total useable volume: 4.1 ft3 (116 L) 20 two-liter flasks or equivalent dry goods
