Beckman Coulter - Cytomics FC 500 MPL
by Beckman Coulter
FC 500 MPL System with MXP Software The FC 500 MPL System provides automated plate and tube based acquisition for cell and bead based assays.
FC 500 MPL System with MXP Software The FC 500 MPL System provides automated plate and tube based acquisition for cell and bead based assays. MXP software allows users to automatically setup assays and rapidly run samples in Microtiter plates for screening and higher throughput analysis. FC 500 Series More Flexibility for Your Cytometry Research, the FC 500 Series is a sophisticated product family equipped with the most advanced technologies available.
FC 500 Series. More Flexibility for Your Cytometry Research, the FC 500 Series is a sophisticated product family equipped with the most advanced technologies available. More Flexibility for Your Cytometry Applications. The Cytomics FC 500 Series is a sophisticated product family equipped with the most advanced technologies available. The FC 500 Series delivers flexible testing, powerful software and a user-friendly interface— features that help scientists optimize their overall workflow efficiency while maintaining true cost effectiveness. Plus, each FC 500 Series system is backed by Beckman Coulter's unsurpassed reputation for quality and service. Precise, Flexible Analysis Every Time. Designed for powerful performance and unmatched simplicity Conducts 5-color analysis from either single or dual laser excitation Improves efficiency by enabling scientists to analyze more antibodies per tube than ever before on an automated system Gives investigators the power to expertly manage every aspect of their flow cytometry studies with the revolutionary CXP software Increased Flexibility with Two Lasers and Multiple Fluorochromes. Equipped with a collinear second laser that maintains a stable alignment with a single beam path and allows greater versatility in antibody and fluorochrome choices. Provides versatility to use either PC5 or APC as the fluorochrome for FL4 in multicolor immunophenotyping applications. Eliminates the need for time delay calculations and the challenges associated with spacially-separated beams. Wavelength independent detectors facilitate application development Simplified Multicolor Analysis with Advanced Digital Compensation (ADC. Beckman Coulter's ADC technology provides superior correction of spectral overlap and more accurate results. With ADC technology, biological samples can be used for automated color compensation, without the limitations of latex beads. Only Beckman Coulter flow cytometers offer patented Digital Signal Processing (DSP) for excellent linearity, drift-free amplification and color compensation. The FC 500 with ADC also enables investigators to: Perform digital signal processing with 20-bit data in real-time. Obtain fast, intuitive compensation feedback to set or fine-tune compensation manually with the QuickCOMP feature. Increase the visualization of low intensity fluorescence populations To accommodate numerous configurations, the FC 500's user changeable filters provide fluorochrome selection flexibility. Customized Photomultiplier Tubes (PMTs) detect a broad range of wavelength emissions, which can be used for virtually any dye excited by 488 or 635 nm lasers. Five-Color Analysis From A Single Laser Has Never Been Easier. Only the FC 500 can be used with a variety of fluorochromes to analyze five colors (FITC, PE, ECD, PC5 or APC and PC7) using either one or two lasers. Investigators could also use Beckman Coulter's IOTest multicolor reagents and drop in their choice of additional conjugated antibodies to make their own combinations. Performs five-dimensional automated phenotyping analysis with Prism, a unique data reduction display allowing analysis of up to 32 individual phenotypes in a single plot. Extends multicolor analysis to utilize the full visible emission spectra, which further boosts the level of flexibility that can be achieved
Components: Height Width Depth Weight Computer 15.75cm 53.34cm 42.55cm 18.14kg (6.2in) (21in) (16.75in) (40lb) Cytometer 61.0cm 97.8cm 88.9cm 84.8kg andMPL (24in) (38.5in) (35in) (187lb) Monitor 42.7cm 40.5cm 43.8cm 22kg (typical) (16.81in) (15.94in) (17.25in) (48.4lb) PowerSupply 50.8cm 45.7cm 66.0cm 54.4kg (20in) (18in) (26in) (120lb)
FDA AlertsView All
Class 1 Recall: Synaptive Medical Recalls BrightMatter Guide...
Class 1 Recall: Zimmer Biomet, Inc. Recalls Spinal Fusion and...
Class 1 Recall: Oscor Recalls TB Temporary Bipolar Pacing Leads...
