Beckman Coulter - Epics XL and XL-MCL
Flow Cytometer
The Beckman Coulter EPICS XL flow cytometer combines the analytical power of a research system into a compact and ergonomically designed unit that speeds up sample throughput. This model is self-contained and biohazard safe. User-adjustable filter elements increase both flexibility and versatility in research settings. This EPICS XL flow cytometer is highly capable of analyzing up to four colors of immunofluorescence from a single air cooled laser. The EPICS XL model is ready for other multi-color applications including multiparametric DNA analysis, platelet studies, reticulocyte enumeration, cell biology/functional studies and as well as a broad range of research applications. High volume users can utilize the XL-MCL system which offers a walk-away sample handling with a Multi Carousel Loader (MCL). This Beckman Coulter XL-MCL flow cytometer system utilizes color-differentiated fluorescence and light scatter measurements to analyze cells. The laser-based flow cytometer is an enhanced model that produces throughputs of up to 100 samples per hour. A positive bar-code identification technology and true vortex mixing prior to aspiration are combined in this feature-packed model.
FORUMSView All (3)
0Replies8 years ago | Beckman EPICS Coulter Cytometer Video Reply |
0Replies9 years ago | System II Software Where I can download or buy software for equipment? Reply |
0Replies13 years ago | Memory of List mode My DOS software send me a caution about the memory which became less than 20 kb, how can increase my memory in spite of I have about 36 GP in ‘D’ drive not used.Reply |
VIDEOS
- 3-color fluorescence with 4-color option
- Air-cooled 488nm 15mw laser
- 10u x 90u light beam
- Detector Range: 300nm-800nm
- Flow-Cell Size: 250u x 250u BioSense
- Max analysis rate: >3300 cells/sec
- Min Cell Size, um: 3300 cells/sec
- Color dot density; contour, isometric, tomogram, overlay, legend and projection plots. PRISM displays; color precedence or color-blend gating; automatic Boolean logic gate creation; 32 gates per file, real-time statistics.
- Intel Pentium processor and 4 network transputers for digital signal processing.
- Signal-intensity display, biohazard-safe triple-fluid (sheath/cleanse/waste) system with automated functions and variable flow rate; auto setup; SYSTEM II software with acquisition, list mode, multigraph, reports and utilities.
- Features FastSet and CellTracker. Opt tetraONE SYSTEM software automates 4-color acquisition and analysis. Retic-ONE SYSTEM software for reticulocyte enumeration.
- The XL system features the capability to analyze up to 4 colors of immunofluorescence from a single air cooled laser.
- The instrument is self contained and biohazard safe. The user retains the flexibility to change filter elements for versatility in research settings.
- For high volume users, the XL-MCL system offers walk away sample handling for superior efficiency with the Multi Carousel Loader (MCL).
- The XL remains the only flow cytometer to offer state-of-the-art Digital Signal Processing (DSP) for reliable linearity and drift-free amplification and compensation.
- The XL SYSTEM II™ software fully automates instrument set-up and compensation for 2, 3 and even 4-color applications.
- The XL is available in 3 or 4-color configurations, with or without the MCL. Ask your Beckman Coulter representative about the configuration that best meets your laboratory's needs.
Height | 20 in |
Length | 22.5 in |
Weight | 140 lbs |
Width | 24 in |
- Operation Color Option :3-color fluorescence with 4-color option
- Cooling:Air-cooled 488nm 15mw laser
- Beam: 10u x 90u
- Detector Range: 300nm – 800nm
- Analysis Range: 3300 cells/sec minimum
- Min. Cell Size – um: 0.5 Maximum
- Max Analysis Rate: Greater than 3300 cells/sec
FDA AlertsView All
Class 1 Recall: Synaptive Medical Recalls BrightMatter Guide...
Class 1 Recall: Zimmer Biomet, Inc. Recalls Spinal Fusion and...
Class 1 Recall: Beckman Coulter Life Sciences Recalls FC 500 and...
