Beckman Coulter - Avanti J-E
by Beckman Coulter
Compact High Performance Centrifuge that fits directly in your lab.
Compact High Performance Centrifuge that fits directly in your lab. Whether your application is related to Cellomics, Genomics, or Proteomics, Avanti J-E with speeds up to 21,000 rpm (53,300 x g) coupled with powerful *SR drive technology provides you with fast separations.              A comprehensive line of labware, with up to twenty-four 96-well microtiter plate processing, 4 x 1L bottles, and disposable HarvestLine System Liners extend the versatility of this centrifuge. For clinical research applications, conical tubes and bottles for swinging bucket rotors spin volumes of 15, 50, 250, and 500 mL for effective blood component isolation with a variety of gradient kits.              The J-E is energy efficient for low heat output plus the quiet operation ensures a comfortable, productive work environment.
FORUMSView All (3)
-jrivera
8 months ago
Need service manual
Hello, trying to find a service manual for an Avanti J-E centrifuge to view the spindle parts breakdown.
Thanks,
JR
Equipment: Beckman Avanti J-E
-Beily
3 years ago
S7 system error
The centrifuge displays "S7 system error". This error comes on after power outages. My warranty is out. I did "clear-911-enter" and it did not work. Please DO NOT give obvious answers such as "call the service people". Reply
-geords22
10 years ago
H7 and H8 error
I am having problem H7 and H8 error, we have contacted the technical support of the company and they said that we need to replace the ROTOR ID HALL EFFECT with part number 369082. They are charging us about 1,200 dollars for the parts and services since it also involve the calibration of the hall effect to the rotor. We are thinking of doing the replacement by our selves to save some. Can any one help us on how to do the calibration procedure? or is there any other way to do the repair instead of buying the parts? Thank you.
[list]    [*] Quick on the job - Shorter run times mean more discovery for you. Avanti J-E's high torque switched reluctance (SR) drive gives you more time at speed and less time getting there.    [*] Shares lab space with others - The Avanti J-E is about the size of a portable dishwasher. The small footprint gives you the freedom to place it right in your lab, so it's where you need it, when you need it.    [*] Conservative and Resourceful - Avanti J-E uses a maintenance free vacuum to reduce friction on the rotor, allowing for a smaller motor and compressor that generates less heat, and less energy usage. These energy efficient components not only prolong the life of the centrifuge, but also increase savings when amortized over time.    [*] Widely respected in rotors - For Volume requirements ranging from microplates to 1-liter bottles, Avanti J-E's extensive rotor library maximizes capacity and optimizes g-force. The library includes: general purpose, high capacity (4 liter), and biosafe certified rotors with patented dual locking lids for safe sample transportation.    [/list]
Height36 in
Length 31.5 in
Weight589 lbs
Maximum Speed21000 rpm
Width25 in
[list]    Accel/Decel Rates 2/3       Set Temp Range (1° increments) -10 to 40°C       Temp Control + 2° of set temperature       Speed Control + 50 rpm of set speed       Ambient Temp Range 15° to 35°C       Drive Type Cooling SRDrive / Air Cooled       Power Usage Heat Output 2.0 kW / 6900 Btu/hr     [/list]
