Beckman Coulter - Avanti J-26XP
High throughput in under 10 minutesThe Avanti J-26 XP Series is designed for high throughput and versatility. Teamed with the J-LITE® JLA-8.1000 6-liter rotor, polycarbonate and polypropylene bottles, and disposable HarvestLine System Liners, the Avanti J-26 XP centrifuges can process 6 liters in 10 minutes. These are versatile high-performance systems as well, capable of running the full line of Beckman Coulter high-performance rotors-including the AllSpin JS-5.3 Rotor with optional microplate carriers and adapters for conical tubes and bottles.
7Replies3 years ago | Beckman Avanti J-26 XP Centrifuge(Dead) Beckman Avanti J-26 XP Centrifuge(Dead) I'm an Electronic Technician servicing Instrumentation within our facility. Have a Avanti J-26 XP in which the front panel/keypad is dark. Have removed the front and rear panels. Checked/verified 240v legs into and out of the switch/breaker - all fine. Voltage is making it to small Power Supply mounted on rear wall. However, I have no schematics to show what the voltages "out" should be on multipin strip at base of supply. Secondly, I have checked the fuses on the front mounted control board - all fine. With power on and interlock defeated I verified voltage test points at edge of board- all fine. There is one green led lite as well as two yellow leds lite ("front & rear" designated on silk screening on PCB). I have not begun to disassemble front control panel/keypad assembly at this point. Without a schematic or service manual I may have performed all troubleshooting common sense would dictate. Any assistance would be greatly appreciated. Thank you, DaveReply |
2Replies9 years ago | need part info anyone have the part number list for this unit, maybe a service manual, or better yet, I need a tach sensor and or part number. any help greatly appreciated! Reply |
[list] The ultimate balance of high performance and high throughput [*] Accommodates all Avanti J rotors*, forces to 82,000 x g (26,000 rpm) [*] Six-liter batch throughput for bacterial and cell membrane isolation at forces up 15,900 x g, using the J-LITE JLA-8.1000 rotor [*] DNA sample prep capability with up to 24 microplates with the AllSpin JS-5.3 Rotor [*] 3 liter and 4 liter swinging-bucket rotors Fast and Efficient [*] Fastest accel and decel times with exclusive SR Drive technology [*] Low heat output and low energy consumption [/list]
Height | 34 in |
Length | 34 in |
Weight | 640 lbs |
Maximum Speed | 26000 rpm |
Width | 28 in |
[list] Accel/Decel Rates 2/3 Set Temp Range (1° increments) -10 to 40°C Temp Control + 2° of set temperature Speed Control + 10 rpm of set speed or 0.1%, whichever is greater Ambient Temp Range 16° to 38°C Drive Type Cooling SRDrive / Air Cooled Power Usage Heat Output 2.0 kW / 6900 Btu/hr [/list]
