Beckman Coulter - Avanti J-30I
by Beckman Coulter
The Avanti J-30I High-Performance Centrifuge System gives you the fastest separations possible - in the shortest amount of time. Swinging-bucket and fixed-angle rotors provide maximum separation forces in excess of 100,000 x g at speeds up to 30,000 rpm. Your productivity is ensured by unmatched accel/decel rates and an easy run set-up. Your sample spends more time at full force and less time in the centrifuge.
0Replies14 years ago | Service manual Hello every body! I need some materials for repair Avanti J-30I. So could you please send to me its service manual if you can? Tam Viet email: servicealltheworld@yahoo.comReply |
[list] Near-Ultracentrifuge Forces [*] Over 100,000 x g means fast protein separations in the Avanti J-30I and the JA-30.50, the highest g-force fixed-angle rotor available in a high-performance centrifuge. [*] Subcellular organelles effectively separated by rate zonal centrifugation with the JS-24.38, a 6 x 38 mL swinging-bucket rotor High Throughput [*] Four-liter batch throughput for bacteria and cell membrane isolation using the JLA-9.1000 J-LITE® rotor at 16,800 x g. [*] DNA sample preparation in up to 10 microplates with the JS-5.9 Rotor. Fast and Efficient [*] Fastest accel and decel times with exclusive SR Drive technology. [*] Low heat output and low energy consumption. [/list]
Height | 86 cm |
Length | 86 cm |
Weight | 310 kg |
Maximum Speed | 30000 rpm |
Width | 71 cm |
[list] Accel/Decel Rates: 12/13 Set Temp Range: (1° increments) -20 to 40°C Temp Control: + 2° of set temperature Speed Control: + 10 rpm of set speed or 0.15%, whichever is greater Ambient Temp Range: 16° to 38°C Drive Type: Cooling SR Drive / Air Cooled [/list]
