Philips - IntelliVue MP5
by Philips
The IntelliVue MP5 offers advanced features such as an intuitive touchscreen with clinical measurements, and clear display, and one-touch commands.
The Philips IntelliVue MP5 is a compact, rugged multi-parameter patient monitor designed for high-acuity care environments both in and out of the hospital. Engineered for portability and reliability, the MP5 delivers real-time vital signs monitoring and advanced IntelliVue functionality in a durable housing built to withstand demanding clinical conditions.
Featuring an intuitive touchscreen, crisp high-resolution display, and one-touch commands, the IntelliVue MP5 simplifies workflow while providing clinicians with accurate measurements of blood pressure, heart rate, oxygen saturation (SpO‚), temperature, and other critical parameters. Advanced Clinical Decision Support tools, including Horizon Trends, ST Map, and ProtocolWatch, provide actionable insights when it matters most, enhancing clinical confidence and supporting informed patient care decisions.
From a biomedical engineering perspective, the IntelliVue MP5 offers robust durability, ease of maintenance, and seamless integration with hospital networks and electronic medical records (EMR), ensuring dependable performance and optimized monitoring infrastructure across acute care, transport, and procedural settings. (Generated by AI)
FORUMSView All (12)
-CBET Neil
Wed Apr 10 2024
disassembly
need step-by step disassembly instructions
Equipment: Philips - IntelliVue MP5
-ewthomas
Fri Feb 02 2024
Neonatal to Adult
Can a neonatal config be changed to adult config on the monitor or does it need to go in for service? Thanks
-William123
Tue Apr 20 2021
MP5 set in a different language
Any way to get around this? The service manual does not really help. Is there a way to change the language?Reply
[list]        [*] Offers commonly required measurements, built-in, with no user setup necessary for typical use (ECG, SpO2, NBP, choice of two invasive pressures and temperatures, choice of CO2 monitoring, and compatible with anesthesia monitoring modules)         [*] Wired and wireless networking for continuous connection, no matter where patients are located on the network         [*] Connects to the IntelliVue XDS Large Display to add a high-resolution larger bedside display to clearly see vital information at a glance and to provide remote-control functionality         [*] Telemetry as a parameter (TAAP) displays telemetry data through a direct connection to a telemetry transceiver         [*] Wireless telemetry as a parameter (WTAAP) expands monitoring capabilities to provide untethered in-room access to ECG/SpO2 data in near-real time        [/list]
