Philips - IntelliVue MMS X2
by Philips
Philips IntelliVue MMS X2 is a combined multi-measurement module and transport monitor, ingeniously lightening the load for patient transport.
Philips IntelliVue MMS X2 is a combined multi-measurement module and transport monitor, ingeniously lightening the load when it comes to patient transport. At just 1.2 kg (2.7 lbs), it’s small enough to go anywhere and powerful enough to go everywhere. It’s a rugged transport monitor that’s also a measurement module, offering continuity of patient data and truly seamless transport across all levels of patient monitoring.              The IntelliVue MMS X2 is small in size and big in capability. Unplug and go in a single step, helping to reduce error and improve patient care. Gain greater clarity through exclusive integrated Clinical Decision Support features that help make it easier to focus on the patient at every point.
FORUMSView All (11)
-RJ_SA
Thu Jan 13 2022
Excitation Voltage
Does anyone know what the excitation voltage is the device delivers through its IBP port to a connected pressure transducer? The manual only refers to the ANSI standard (5uV/V/mmHg). Also, having trouble with the device recognizing a TruEdwards transducer. Says it cannot detect it. Switched out the Xducer with others, followed the troubleshooting steps in the manual, but did not get it to work. Any help is appreciated!Reply
8
-Mats Hilmersson
Fri May 28 2021
Excitation voltage
Does anyone know the excitation voltage in the IBP pressure connection in Intellivue or other Philips equipment? Reply
-Chris S
Thu Jan 24 2019
Converting to IIT wireless
Hello, I have a non-wireless version of an X2 module. I am looking to add the IIT wireless feature. Does anybody know if it is just as simple as ordering and installing the IIT board and Antenna Board? I looked at the main board, and it has the same connection as our existing Wireless modules. Thanks in advance.Reply
[list]      [*] One of the lightest, smallest and rugged critical care transport monitors available       [*] An MMS with display, alarm capability, 3-hour removable battery, and extended trends       [*] Crisp, colorful touchscreen with 3.5” display with seamless electronic recording       [*] Connects to the IntelliVue XDS Large Display to add a high-resolution larger bedside display to see clearly see vital information at a glance and to provide remote-control functionality       [*] Transmits data wired or wirelessly to the IntelliVue Information Center, or just plug and play to upload data to another IntelliVue monitor       [*] Wireless telemetry as a parameter (WTAAP) expands monitoring capabilities to provide untethered in-room access to ECG/SpO2 data in near-real time       [*] Philips Green Flagship product, meeting rigorous environmental standards in manufacturing and use      [/list]
Weight2.7 lbs
