Multi-Parameter
The IntelliVue MP2 is a remarkably light, flexible, and durable wearable transport monitor thats easy to use during transport or in low acuity settings, both in and out of the hospital.
Ask a New Question0Replies-MedWrenchManager 7 years ago | 7 years agoPACFAQ: Common SpO2 Cables & How To Tell The Difference
Covering the most common SpO2 cable connectors used in most Healthcare Clinics. With Free Downloadable PDF Cheat Sheet. This information with help you identify which connectors you will need…and hopefully take the guessing game out of your ordering process.
Sp02 Cable Connector Cheat Sheet Available for download here:
http://pacificmedicalsupply.com/pac-f...
Today we are going to walk you through the most common SpO2 connectors used on patient monitoring equipment.
Nellcor DB9 OxiMax
The DB9 connector is the most common connector for finger sensors. It can be identified by 9 pins and the color Purple
Philips D-Connect
A D-Connect connector by Philips can be identified by 8 pins and the color Blue
Datascope
A Datascope connector by GE can be identified by 8 pins and the color white
GE Ohmeda
A GE Ohmeda can be identified by 10 pins and the color gray
GE Marquette
A Marquette connector has three different styles
The GE Marquette standard Ohmeda can be identified by 11 pins and the color blue Blue
The GE Marquette with Nellcor OxiMax can be identified by 11 pins and the color blue
The GE Marquette with Masimo can be identified by 11 pins and the color Blue
GE Hypertronics Datex-Ohmeda
The GE Hypertronics Datex-Ohmeda connector can be identified by its 7 pins and the color Black
3M
The 3M connector has four different styles.
The Nellcor 3M OxiSmart can be identified by its 14 pins and the color Gray
The Nellcor 3M OxiMax can be identified by its 14 pins and the color Purple
The Masimo 3M LNC connector can be identified by its-14 pins and the color White
And the Masimo 3M LNC-20 connector cab be identified by its 20 pins and the color Red
Masimo LNOP
The Masimo LNOP connector can be identified by F-Tab and the color White and Red
Masimo LNCS
The Masimo LNCS connector can be identified by 9 pins and the color gray
To learn more about SpO2 cable connectors, to cross reference, view all our in-stock cables and to download a free SpO2 and Extension Cable Catalog, visit pacificmedicalsupply.com/PacFaq
Reply |
0Replies-Data Entry Coordinator 7 years ago | 7 years agoHow To Locate software and options on a Philips MP Series IntelliVue Monitor Reply |
1Reply-William123 8 years ago | 8 years agoPower Supply Board
The Connector on my MP2 Power Supply Board was broken so i bought a new supply board and now the unit is saying no serial number on the screen. How do i fix that? Reply |
VIDEOS
PACFAQ: Common SpO2 Cables & H...
Covering the most common SpO2 cable connectors used in most Healthcare Clinics. With Free Dow...
How To Locate software and opt...
- Compact and easily carried by patients in low-acuity settings
- Each NBP measurement generates a column in the vital signs trend table
- Wireless telemetry as a parameter (WTAPP) expands monitoring capabilities to provide untethered in-room access to ECG/SpO2 data
- Allows quick visibility of patient data, and enhance compatibility with standard software
