Philips - SureSigns VM6
by Philips
The SureSigns VM6 patient monitor provides you with numerous essential measurements in one easy-to-use, compact patient monitor. [b]SureSigns VM6 goes beyond the basics[/b] Measurements include user-selectable 3 or 5-lead ECG, pulse oximetry, non-invasive blood pressure, respiration, basic arrhythmia, temperature, optional invasive blood pressure, and optional recorder, while an intuitive navigation puts your most commonly used features at your fingertips
1ReplyTue Nov 10 2015 | Equipment Malfunction The blood pressure cuff will inflate. The monitor will display equipment malfunction and will not display the blood pressure reading. All connections have been checked. Reply |
1ReplySat Mar 08 2014 | Printing Issue I have two of these units that will spontaneously begin to print and run out the whole roll off paper even when just sitting in Demo Mode. Philips tech support is stumped. Has anyone else seen this? Reply |
0RepliesSun May 12 2013 | Silience the beep
how to silence the beep which happens every second when the equipmnt is on and sensor is capturing the SPO2 waves? Regards. Reply |
[list] [*] Measurements include user-selectable 3 or 5-lead ECG, pulse oximetry, non-invasive blood pressure, respiration, basic arrhythmia, temperature, optional invasive blood pressure, and optional recorder [*] Intuitive navigation puts your most commonly used features at your fingertips [*] Large (8.4”, 20.3 cm) and crisp color display is bright and easy to read, even in low-light situations [*] Up to 96 hours of measurement trends [*] Philips SpO2 technology compatible with a wide variety of adult, pediatric, and neonatal sensors [*] Spot-check mode for vital signs collection on multiple patients [*] Lightweight, yet durable, with a comfortable handle for easy mobility [*] Lithium ion battery life of 4 hours [*] Integrated strip recorder for convenient documentation (optional) [/list]
| Height | 8.6 in |
| Length | 5.7 in |
| Weight | 7.1 lbs |
| Width | 10.2 in |
