Philips - SureSigns VM4
Just what you need in a portable bedsideThe SureSigns VM4 has the complete solution: a patient monitor with ECG and vital signs measurement in one easy-to-use, compact package.
SureSigns VM4 doesn’t miss a beat
Your days are already very busy. You’re doing more with less, and that is not likely to change anytime soon. Trust Philips to give you what you need to help care for your patients. Basic patient monitoring has never been more clear.
FORUMSView All (3)
6Replies3 years ago | NBP Malfunction Originally the user complained that the diastolic pressure reading was too high. Attempted an NBP calibration but the pump did not come on. I've replaced the following: - NBP pump module - Mainboard - Power supply module I am still getting an NBP malf and pump is not working which is causing it not to calibrate. Reply |
0Replies11 years ago | Pressure Transducer How can I verify the transducer isn't working? Is it as simple as blowing in the NIBP port and if it doesn't register..? Reply |
1Reply13 years ago | battery replacemnt How do you replace the batteryReply |
- Measurements include 3-lead ECG, pulse oximetry, non-invasive blood pressure, predictive temperature (optional), and optional recorder
- Intuitive navigation puts your most commonly used features at your fingertips
- Large (8.4”, 20.3 cm) and crisp color display is bright and easy to read, even in low-light situations
- Up to 96 hours of measurement trends
- Philips SpO2 technology compatible with a wide variety of adult, pediatric, and neonatal sensors
- Spot-check mode for vital signs collection on multiple patients
- Lightweight, yet durable, with a comfortable handle for easy mobility
- Lithium ion battery life of 4 hours
- Integrated strip recorder for convenient documentation (optional)
Height | 8.6 in |
Length | 5.7 in |
Weight | 6.9 lbs |
Width | 10.2 in |
