Beckman Coulter - Optima L-100K
Unmatched versatility, reliability and safety.Capable of generating 802,000 x g at speeds up to 100,000 rpm, Beckman Coulter's Optima L-100 K Ultracentrifuge enables you to perform — in less time — more separations, such as high-purity plasmid DNA, sub-cellular particles and virus isolation. This versatile floor model operates with a broad range of superb rotors, including zonal and continuous flow for large-volume separations. The L-100 K offers the reliability of a vacuum-encased induction drive, the simplicity of user-friendly, microprocessor-based control, and environmentally-friendly cooling system that eliminates the need for CFCs and other harmful liquid refrigerants. All this makes the L-100 K the right choice for your laboratory's routine separation needs.
FORUMSView All (3)
1Reply2 years ago | Screen Fades to solid black I have a Beckman Coulter Optima L-100K Ultracentrifuge. When I turn the machine on the screen goes from with then in the middle area it starts getting black until the whole screen becomes black. Has anyone had this before? I replaced the screen but no luck. Thanks This is the color screen modelReply |
2Replies6 years ago | Error Message: DIAG 66: Drive Malfunction I have a 1990's model Beckman Optima XL-100K centrifuge. Had been running well for over a year. Recently, the recent runs have shut down after about 5 minutes. The unit will restart and shut down about 5 min after hitting speed. There are no weird noises that I can ascertain. The centrifuge has been shutting down with the above error message. Among things I suspect is that the oil in the drive needs changing. I looked on line and there is no informatiion that I could find. When I querried Beckman about buying a service manual, the price was $3,213. Seems a bit steep for a nearly 30 yr old centrifuge. Any ideas on how to proceed? What can a reasonably competent user investigate and service to correct this situation.Reply |
0Replies13 years ago | question hi..i m one of BC optima L-100K user.i m running my recombinant protein extraction project that require this machine. my question is.. i would like to run this machine at 44K rpm for 1hr & 20 mins at 4 C ..how long does it take for this machine to run once i key in all the setting that i want...do i have to wait the vaccum drop until |
Height | 47.5 in |
Length | 26.5 in |
Weight | 1025 lbs |
Maximum Speed | 100000 rpm |
Width | 37 in |
Speed control: ± 20 rpm of set speed
Sample imbalance tolerance: ± 5 mL or 10% whichever is greater
Drive cooling: Air-cooled
Set temperature range: 0°C to 40°C in 1°C increments
Temperature control: ± 0.5°C of set
Ambient operating range: 15°C to 40°C
User-settable programs: 9 user programs, with delayed start capability
Acceleration/Deceleration rates: 2 Accel/3 Decel
Heat output: 1.0 kW/h (3,400 BTU/h)
