Scientek - SWC 015-041G
by Scientek
Scientek’s Warming Cabinets provide a constant preset temperature within each chamber for surgical solutions, blankets and other clinical items.
1ReplyFri Sep 04 2026 | Door handle Where to purchase new lower door handle assembly & how to install with out dropping the mounting plate into the door frame anddddddd goooooooo........ Equipment: Scientek - SWC 015-041G Reply |
0RepliesThu Jun 20 2019 | Condensation Has anyone had an issue with condensation in these warmer cabinets? I have one that is collecting water in the rubber seal at the bottom of the door and dripping down on to the floor. I suspected a tear in the seal but found it is in good condition with no breaks or gaps. Staff states that blankets are dry when placed inside. Just wondering if anyone has had this issue before?Reply |
• High quality stainless steel construction inside and out • Individual temperature control per cabinet (oF or oC) • Full access within cabinet load space • Fan forced hot air convection over electric heating element • Fully insulated cabinet walls and doors • Simple construction for ease of operation and maintenance • LED (Light Emitting Diode) temperature display and set point • Full perimeter silicon gasketed doors • Positive door closure with mechanical latches • Automatic high limit temperature cutout and reset OPTIONS: ADD SUFFIX G FOR GLASS DOOR OPTION AFTER EACH SECTION REQUIRED ADDITIONAL OPTIONS AVAILABLE ITEM # DESCRIPTION SWC-SA SEISMIC ANCHORING SWC-CAST 4 CASTERS (2 with BRAKES) FACTORY INSTALLED SWC-S ADDITIONAL STAINLESS STEEL SHELF SWC-SST STAINLESS STEEL WALL TRIM FLANGE (2 SIDES, 1 TOP) ITEM # DESCRIPTION SWC-AA AUDIBLE ALARM (PER COMPARTMENT) SWC-HGP HOSPITAL GRADE ELECTRICAL PLUG SWC-LH DOOR HINGE-LEFT HAND MOUNTED (NO CHARGE) SWC-VOLT SPECIAL ELECTRICAL VOLTAGE (OVERSEAS)
INTERIOR SHELF SURFACE AREA 15.625 sq.ft. - 0.438 sq. M. INTERIOR CABINET SIZES WIDTH 25.625” - 651mm DEPTH 17.56” - 446mm HEIGHT WIDTH EXTERIOR CABINET SIZES WIDTH 30” 24” 762mm DEPTH 24” 610mm HEIGHT 74” 1880mm See PDF page for more details [url]http://www.scientek.net/pdf/Scientek_SWC-15-41-28_Warming_Cabinets_Brochure.pdf[/url]
