Sartorius - Centrisart A -14
by Sartorius
High-speed bench-top centrifuge.
Sartorius Stedim Biotech’s Centrisart A -14 is ideally suited for use of VoluPAC biomass determination tubes, Vivaspin 500 ultrafiltration devices and all other standard microtubes. The large display allows high legibility of the values for speed, relative centrifugal force and running time. All parameters are set quickly and simply with push buttons. The Centrisart A -14 is equipped with a 12-place polypropylene rotor and operates smoothly and quietly.
[list]      [*] Large capacity ( 12 x 1.5-2.2 ml tubes, optionally 18 or 24 tubes)    [*] Top speed of 14,800 rpm, very high relative centrifugal force of 16,163 x g    [*] Bright display offers good legibility; choice of rpm/RCF    [*] Simple, direct operation using push buttons    [*] Shortrun, Softstart and Softstop – the only one to offer this feature in its class    [*] Large selection of additional polypropylene or aluminium rotor    [*] Air cooling ensures minimal temperature increase of samples in the rotor bowl    [/list]
Height176 mm
Length 212 mm
Weight5.4 kg without rotor
Maximum Speed14800 rpm
Width266 mm
[list]    Power consumption: 95 W       Kinetic energy max: 1721 Nm       Interference suppression: EN 61326       Max. acceleration:       - Rotor 12092 13 sec.       - Rotor 12084 20 sec.       Max. deceleration:       - Rotor 12092 11 sec.       - Rotor 12084 14 sec.     [/list]
