Sysmex - XS-1000i
by Sysmex
CBC + 5-part differenital analyzer that requires less than four feet of counter space
The XS-1000i provides rapid, reliable test results from just 20uL of sample for assistance in patient diagnosis and therapeutic monitoring. It utilizes the same state-of-the-art diagnostic power and accuracy as the X-Series (XE-Series, XT-Series) of high volume analyzers with comparable results. Now you can spend less time managing equipment and handling samples and more time on the critical analytical work in your lab.
FORUMSView All (24)
-Dice
24 days ago
interface
connect to hostReply
-Labdude
6 months ago
Questioning the numbered amount of manual microscopic slides we are doing?
Seems toward the end of every month we start doing extra slides. If we started doing the monthly maintenance sooner (bleaching procedure), would this decrease the number of slides we perform?Reply
-Loupe
6 months ago
Analyzer stays on stand by mode
The CBC Analyzer is connected to the IPU (ver 00-30 built 34) via a linksys USB 2.0 /Ethernet adapter. IP address 192.168.1.125 Sub mask : 255.255.255.0 Gateway : 192.168.1.1. DNS : 212.27.40.240 & 241 The IPU is also connected to a Linksys router via a broadcom ethernet adapter. IP address 192.168.1.120 Sub mask : 255.255.255.0 Gateway : 192.168.1.1. DNS : 212.27.40.240 & 241 The router is connected to a centralization PC (to launch the analysis) How can I get the IP config of the analyzer. I tried ipconfig /all command on the IPU, but the pannel only shows the 2 ethernet adapter config installed on the IPU (both pings ok) When I switch on the analyzer at request of the PC, the red led of the analyzer remains on red and there is no reaction from it ? Does someone have an explanation for this ?Reply
• Effective diagnostic capabilities utilizing
fluorescent flow cytometry
• CBC and 5-part differential
• Simplicity in operation for streamlined workflow
• Standardization across Sysmex platform
• Proven reliability as a member of the X-Family
of products
  • For better reliability, longer life and more efficiency the XS-1000i utilizes an avalanche photodiode with a small laser bench and integrated electronic boards. * For enhanced diagnostics, WBC cell populations are measured using fluorescent flow cytometry with side scatter and side fluorescence.
Models XS-1000i
– closed tube sampling
XS-1000i – with auto sampler (closed tube)
XS-1000i System Includes XS-1000i analyzer -
12.6” W x 15.9” H x 16.3” D; 52.8 lbs.
All in one computer/monitor
Bar code reader
Laser printer
Auto sampler (optional) -
16.7” W x 15.9” H x 24.2” D; 74.8 lbs.
XS-1000i Specifications
Operating System – Windows® XP
Sample Storage – 10,000 records
with scattergrams
Ideal lab testing volumes –
up to 60 CBC+DIFF/24hr
Discrete test options – CBC or CBC+DIFF
Common reagents and e-CHECK control as
XE and XT-Series
Measurement Principles RBC/PLT
– Sheath flow direct current as on
XE and XT-Series
WBC – Semiconductor laser flow cytometry
HGB – Colorimetric method (SLS)
Testing Parameters
21 Parameters: WBC, RBC, HGB, HCT,
MCV, MCH, MCHC, RDW-SD, RDW-CV,
PLT, MPV, NEUT%, NEUT#, LYMPH%,
LYMPH#, MONO%, MONO#, EOS%, EOS#,
BASO%, BASO#
Throughput
Single sample mode – 60 samples/hr
Auto sampler mode – 53 sampler/hr
Quality Control
20 files
L-J or X-barM measurement
Common QC material to XE and XT-Series
Linearity Specifications
WBC 0 - 400 X 103 µ/L
RBC 0 - 8.00 X 106 µ/L
HGB 0 - 25.0 g/dl
HCT 0 - 60%
PLT 0 - 5,000 X 103 µ/L
