Sysmex - XE-2100
Hematology Analyzer
This instrument has a history of reliability and productivity to provide the best efficiency for the hematology laboratory. Using a patent fluorescent dye and hydrodynamic focusing, the XE-2100 provides a unique platelet technology that minimizes review rates and give accurate results.
FORUMSView All (4)
0Replies2 years ago | EDTA tubes Would like information on EDTA tube requirement for use: volume, height, stopper (rubber or hemogard)Reply |
0Replies4 years ago | Manual Rinse Cup part number Does anyone know what the part number is for the manual rinse cup?Reply |
1Reply8 years ago | Spec Sheet Is it possible to get a spec sheet on this device? Thanks. Reply |
- Improved low-end sensitivity
- Rapid reporting to assist clinicians in patient diagnosis and treatment decisions
- Efficient automatic correction of WBC and Diff results
- Decreased false negative and false positive rates with advanced separation from WBCs and RBCs
- Available with every CBC or as a reflexive testing option
- Dimensions / Weight Main unit: 27.8" x 35.9" x 28" / 178 lbs. w x h x d [in] / Sampler: 22.8" x 7.7" x 14.8" / 26 lbs. IPU: 18" x 17.6" x 5.3" / 24 lbs.
- Data Storage 10,000 samples (including graphics)
- Sample Volumes 200μL / 130μL (closed/open mode) 40μL for capillary mode
- Throughput Whole Blood Mode: 150 samples/hr (max.)
- Body Fluid Linearity WBC-BF: >/= 0.050 x 103 /µL RBC-BF: >/= 0.01 x 106 /µL
