Sartorius - SIGMA 3K30
High-speed laboratory centrifuge for swing-out and angle rotors, programmable, with coolingFORUMSView All (10)
0Replies10 months ago | Error 42 troubleshooting. Hey, we met with this same problem we find out that Attached Stabilizer was set in output mode. Once we turn it into Input mode it start working. Also I want to suggest run minimum 30 sec after closing lid. |
1Reply2 years ago | Lid Opening Error I have this centrifuge machine in my lab. Its lid is not opening. It doesn't show any error message. I have restarted many times but failed. How to fix this issue?Reply |
0Replies3 years ago | Troubleshoot Sigma 3K30 says, Drive not enabled. How can I fix the error? Reply |
[list] [*] High-speed refrigerated bench top centrifuge for gravitational fields up to more than 60.000 × g. [*] Maintenance-free brushless drive motor. [*] Speed range between 100 rpm and 30.000 rpm selectable in steps of 1 rpm. [*] Free programming of all run parameters possible. [*] Automatic rotor identification prevents the rotor from overspeeding. [*] Wide range of angle rotors for microliter tubes up to 85 ml capacity. [*] A swing-out rotor is available. [*] Efficient refrigerating machine for temperatures between –20°C and +40°C, possibility of precooling the rotors during standstill. [*] Motorized lid lock for optimal operating convenience. [*] Reliable drive system. [*] Produced according to national and international safety regulations. [/list]
Height | 400 mm |
Length | 650 mm |
Weight | 100 kg without rotor |
Maximum Speed | 30000 rpm |
Width | 550 mm |
[list] Power consumption drive: 700 W Power consumption refrig.: 560 W Interference suppression: EN 55011/B Kinetic Energy max. 43.753 Nm Noise level at max. speed (approx.) : - Rotor 11190 at 5.000 rpm 59 dB (A) - Rotor 12158 at 26.200 rpm 64 dB (A) Max. Acceleration: Rotor 11190 30 sec Rotor 12158 90 sec. Max. Deceleration: Rotor 11190 14 sec. Rotor 12158 58 sec. [/list]
