Sartorius - SIGMA 8K
Floor-standing, high-capacity centrifuge for up to 12 litres, with coolingFORUMSView All (1)
1Reply12 years ago | Temp. Sensor i Need an image that discribe to me how we can replace the old sensor with the new sensor Reply |
- Compact refrigerated floor standing centrifuge for universal use in blood banks, clinical laboratories and research
- Capacity up to 6L in angle rotor 12 × 1L, 6 × 1,5L or 12 blood bags in swing-out rotor
- Solid construction, suitable for continous use
- Maintenance-free drive, high imbalance tolerance up to approx. 80 g
- Speed range 100 – 10.500 rpm
- Automatic rotor identification prevents spinning rotors overspee
- Efficient refrigeration; temperature adjustable between -20 °C and + 40 °C, standstill cooling, with refrigerant R 404a
- Stainless steel chamber
- The lid is hinged on the left hand side
- Easy opening of centrifuge lid via pneumatic springs
- Two motorized lid locks provide safe, assured lid-locking
- Emergency lid opening on power failure without opening of housing
- Ergonomic loading height of just 88 cm
- The user friendly control unit is integrated in the front panel
- Centrifuge fits through a door opening of only 82 cm
- The centrifuge stands on movable castors and adjustable feet to even out the floor
- Easily serviceable
- All international standards are met, e.g. IEC 1010, CE, WEEE Options
- Data logging via RS 232
- Water-cooled compressor
- Sealed housing and watercooled compressors, sterile room version
- Inert gas injection with analysis of the oxgen content in the exhaust emission
Height | 960 mm |
Length | 910 mm |
Weight | 420 kg without rotor |
Maximum Speed | 10500 rpm |
Width | 810 mm |
Power consumption: 6,5 kW
Kinetic Energy max.: 279 kNm
Noise level at max. speed: (approx.)
Rotor 11800 69 dB (A)
Rotor 12505 73 dB (A)
Max. Acceleration:
- Rotor 11805 81 sec.
- Rotor 12505 80 sec.
Min. Deceleration Rotor:
- Rotor 11800 59 sec.
- Rotor 12505 75 sec.
Temperature setting range: -20°C – + 40°C
Min. Rotor temperature: < 4°C
