Smiths Medical - Level 1 H-1200 Fast Flow
by Smiths Medical
Level 1® H-1200 Fast Flow Fluid Warmer with Integrated Air Detector/Clamp
Upon detection of air in the line, the flow of blood and crystalloid is automatically stopped, allowing quick removal of air and restoration of flow without disconnecting from the patient or changing disposable administration sets.
FORUMSView All (8)
-ktstevenson
2 years ago
tubing
How long is the tubing able to be utilized in the Rapid Infuser for blood transfusions? Is it by time frame or by number of blood product infusions? Thank youReply
-awakefie
5 years ago
Check Disposables Alarm
I was trying to PM the unit and found that the check disposables alarm is sounding. I made sure that everything was properly seated, tried 3 different sets and even verified my test set against another unit. I cannot get the alarm to clear. Has anyone else had this issue, and if so, how did you clear it? Both the user and service manuals were not helpful with this issue.Reply
-acoubrough
8 years ago
pm
[list]        [*] On/Off toggle switch used to pressurize chambers        [*] Constant 300 mmHg pressure is applied and maintained        [*] Accommodate standard blood and solution bags        [*] Aluminum heat exchanger transfers heat 1000 times faster than plastic        [*] Counter current 42°C circulating water bath for effective and stable heating        [*] Detects the presence of air in blood and crystalloid        [*] Automatically stops the flow of blood and crystalloid andalerts personnel with audible and visual alarms when air is detected        [*] Allows quick removal of air and restoration of flow without disconnecting from the patient or changing Disposable Administration Sets        [/list]
