Care Essentials - Cocoon CWS 4000
by Care Essentials
Convective Warming System
The Cocoon Convective Warming Machine, CWS 4000, is a mains powered, microprocessor-controlled device.  It delivers a continuous flow of temperature-controlled air through a flexible hose to the warming blanket. The CWS 4000 is lightweight, compact and easy to use. Features include microprocessor controlled, digital temperature sensor system, automatic step-down from 46°C to 43°C after 10 minutes, built in safety monitoring system and a filter status indicator.Other features include washable plastic hose cover and multiple mounting options including cart, stand, IV pole, floor or bed rail - retractable bed hooks for convenience.
-BIOMEDICAL ENGINEERING
10 years ago
FILTER ERROR
STABNDBY LED AND 46 TEMPERATURE CONTROL BUTTONS ARE WORKING.
Safety
  • Duel thermostats, self resetting at 53 degrees
  • Heating element has a thermal safety switch and thermal fuse
Performance
  • Air intake through side vents
  • Hepa filter rated at 0.2 micron efficiency
  • Microprocessor controlled
  • Protective hose cover
Function
  • Self monitoring life and progress filter status
  • Purpose built testing port using Hyperterminal program
  • Retractable bed hook brackets
