Cincinnati Sub-Zero - Warm Air
Improve patient safety and patient outcomesThe WarmAir® system from CSZ safely provides effective air warming therapy to your patient. Because of the unique patented design of our WarmAir® FilteredFlo® blankets, we can utilize a lower velocity blower which supplies gently moving, clean air that minimizes unwanted air currents that may spread contaminants to your patient or staff. All air is filtered before being distributed to the air blanket to prevent airborne bacterial contamination in critical areas. The warmed air is then filtered again as it leaves the FilteredFlo® warming blanket.
The WarmAir® warming unit is compact and lightweight weighing a modest 13.5 pounds (6.1kg) and standing a mere 13.5" (34.3cm) high. The WarmAir® unit easily attaches to CSZ universal stands, operating room tables, stretchers, bed ends, side rails, or IV poles offering versatility. Because of the unique patented design of the FilteredFlo® blankets, CSZ utilizes a lower velocity blower which supplies gently moving clean air. The filtered air warming method minimizes unwanted air currents that may spread contaminants to your patient. Please refer to the photos below demonstrating air flow with the two different air warming methods.
Height | 13.5 in |
Length | 8.75 in |
Weight | 13.5 lbs |
Width | 8.75 in |
NEWSView All
Product Showroom: Warming Systems
Medline PerfecTemp PerfecTemp is an O.R. table pad that incorporates both pressure-reducing high-tech material to reduce the incidence of pressure ulcers and a warming system to combat hypothermia. PerfecTemp is the only warming system available
