Advertisement
GE Healthcare - Lunar Achilles Express
Manufactured by GE Healthcare
Portable and radiation-free
The Archilles Express by GE is a compact ultrasonometer that provides a cost-effective way to evaluate the risk of fracture resulting from osteoporosis. This machine offers low precision error that makes it possible to monitor bone changes. When you buy the Achilles Express, you will be able to perform exams in very little time. It will automatically calculate the STIFFNESS Index to provide a T-score and Z-score.
The GE Archilles Express comes equipped with an internal microcomputer that has the memory capacity for up to 100 patient results. It also has a printer that is built into the system for convenience. This system offers a compact design that requires less than 2 square feet of space. It is lightweight which allows you to transport the machine if necessary.
QUESTIONS & ANSWERSView All
Answers
-arielgnoguera
2 years ago
I need to buy membranes for my Lunar Achilles Express
i need to buy new membranes for my lunar achilles expressReply
Answers
-karl-red
3 years ago
Firmware Error
Acilles Express Version 4.25 tells on display : Firmware error, scanner update neccesary (hope the translation is correct org. in German : firmware-fehler scannerUpdate erforderlich.) any idea? Thank youReply
Answer
-squeck
3 years ago
Achilles express heating issue
Hey there,i cant get my Achilles express to pass the Quality Test. Signal is perfect, but those few seconds after sendeing the signals, where the AE is saying "Testing Heating circuit", with that little clacking sound, is missing. It just says that 1 second, then deflates the membranes and says "failed".It doesnt say "X degrees" when turning on until 37degrees C either. It just says "heating off". Can I reset the heater, need I to decalciy or clean something inside? Any ideas anyone ;-)PetraReply
PREVENTIVE MAINTENANCEView All
Be the first to submit a preventive maintenance post about this equipment
  1. Compact and takes a small amount of space
  2. Lightweight and portable
  3. Proven to indicate fracture risk in women ages 45-75
Bone Density Imaging ModeQuantitative Ultrasound Destometry
Height10 in
Length 24 in
Scan ProtocolsExtremeties (e.g. hands, feet) - Included
Swing Away C-arm CapabilityPortable
Width12 in
NEWSView All
!{article.title}
GE Login Tips from Conquest Imaging
GE login tips from Conquest Imaging
!{article.title}
GE Healthcare Launches the Most Sensitive Clinical PET/CT Scanner in...
GE Healthcare is proud to announce the new Discovery† PET/CT 610 as the first double-digit sensitivity PET/CT scanner* with an absolute sensitivity of 10cps/kBq1, the highest level found on any scanner commercially available.
Advertisement
Ask anything about
Advertisement
For questions about using the MedWrench web site:
(866) 989-7057TOLL FREE  •  (770) 692-8371INTERNATIONAL
support@medwrench.com
MedWrench is in association with:
TechNationMedical DealerOR TodayMD Expo
Testimonials  •  Advertising  •  Privacy Policy  •  Terms and Conditions
© 2017 MedWrench, LLC. All Rights Reserved
Advertisement
