GE HealthCare - Lunar Achilles InSight
by GE HealthCare
The Achilles offers you osteoporosis testing on the go. These lightweight and reliable ultrasound systems assess a patient’s fracture risk within minutes. Transport your system easily and safely. Make transport convenient with an optional, soft-sided, bag and cart. Protect your unit during air travel with a custom hard-sided flight case.
2RepliesWed May 07 2025 | QA failure Detector test failure Looking for 2nd opinion on a old lunar before replacing detector power supply. The detector test fails. I have photos of many test run Equipment: GE Lunar bone density Reply |
3RepliesThu Apr 22 2021 | No start the equipment no pass the initial screen Reply |
2RepliesWed Nov 30 2016 | GE Achilles Insight DOes this model take membranes? What is the up keep other than running a QA Reply |
[list] [*] Automated and self-contained - The standard system is an automated and self-contained unit with an internal printer. The on-board memory stores up to 300 patient results, which you can review or print at your convenience. Printouts are easily attached to permanent patient records. [*] DICOM - DICOM (Digital Imaging and Communications in Medicine) is a standard for transferring digital media images and associated information between devices. The DICOM standard specifies information that vendors must supply about their product, when the product claims to be DICOM standard compliant. [*] Lunar’s DICOM Conformance Statement defines what DICOM protocols our product includes and the details it uses in communication with an existing Picture Archiving Communications System (PACS) or Radiology Information Server (RIS). [/list]
| Scan Protocols | Extremeties (e.g. hands, feet) - Included |
| Swing Away C-arm Capability | Portable |
| Bone Density Imaging Mode | Quantitative Ultrasound Destometry |
