EPPENDORF - Microcentrifuge 5424
Centrifuge
The centrifuge is whisper quiet, even when running without the rotor lid, to improve your lab environment. It provides centrifugation speed up to 21,130 x g (15,000 rpm) with additional spin functions to satisfy all of your applications. The operating concept and overall design are based on in-depth ergonomic studies, making everyday routines faster and easier. A versatile 24-place centrifuge that sets new standards for silence, speed and simplicity!
FORUMSView All (4)
0Replies10 months ago | Lid axle bushing They're not available from Eppendorf anymore, but the ID is 8mm, OD 10mm, flange is 14mm OD and 1mm thick, length 4mm. McMaster-Carr p/n 57785K314 Igus GFM-081013-08, MFM-0810-05, TFM-081012-04, X6FM-0810-10 all work. Reply |
2Replies2 years ago | EPPENDORF - Microcentrifuge 5424 TUB REPAINT Is it worth doing a tub epoxy repaint on 3 Eppendorf 5424 Reply |
2Replies3 years ago | Service manual Iam looking for the service manual for 5425 centrifuge Thank youReply |
- Compact 24-place microcentrifuge
- OptiBowl™ design for whisper quiet operation, even without rotor lid
- Centrifuge lid with a soft-touch one-finger closure for ergonomic and secure lid locking
- Ld opens automatically at the end of the run to prevent sample warming and to allow easy access to samples
- Full-digit speed display for easy reading
- Other features include: SOFT-brake to protect delicate samples; fully adjustable end-of run-alarm (levels 1-5, mute) to reduce noise; short-spin function that can be programmed to your desired speed
Height | 8.9 in |
Length | 12.6 in |
Weight | 29.5 lbs without rotor |
Maximum Speed | 15000 rpm |
Width | 9.5 in |
- Number of rotors: 4
- Acceleration/braking: <14 s/<16 s
- Soft ramp: Adjustable
